1 - 20 of 23 Posts
'04 HB Devilray Merc 25 HP
My buddy said it was one of the best upgrades he did for his 50 2s Yamaha. You need to sand down the reed block extra smooth before adding them. Use 600 grit and make sure no light is coming through after they are installed.
Where would I be sanding to make no light come through? The tips?
The way I understand it is the metal reeds that are on the reed block can push into the material they have been screwed into. For a 50hp 2s Yamaha there was a black material surrounding where the reeds were screwed into. On the Yamaha you can feel the intentions that the old reeds made. Need to make that flush so the new reeds sit without any lift or gaps. You can check by trying to see light through the backside of the reeds once screwed in. I'm no expert but just giving you the info as I've seen it done before. On other motors the reeds may be screwed onto straight metal blocks in which case you can ignore everything I've said. Once you take your reeds off it should be clear.
Discussion Starter · #10 ·
@Boatbrains in the installation manual it says to flatten the mounting face of the reed block. I used a glass table and some 400 grit and got it to where about 50% of the rubber was kissed by the sand paper and 85-100% of the mounting surface (aluminum) was flat. Do you think that is enough? I am testing on the older motor until I get the new (used) power head in. The engine on the boat has some real pop too it now from down low.
I had Boyesen reeds installed on a 2008 yamaha 2 cylinder 2 stroke. Also had head work done to increase compression. I also have the same motor completely stock. I can tell no difference in the two, performance-wise. The modded motor does, however, require premium fuel(because of the increased compression-not the reeds).
The boyesen reeds work fine, but I didn’t notice any performance gains. In my experience, they provide no benefit over stock reeds on this particular motor. I think the two cylinder 25’s just don’t have a lot of easy hp gains to be had through modifications- now the 3 cylinder motors- that’s a different animal!
Did exactly this on my 225 Merc, went with Carson reeds after having injectors flow tested and servicing fuel rails. What you are trying to accomplish is what BB has pointed to; the best sealing surface (w/o going through the rubber) so that the reeds lay flat on the sealing surface when the fuel mixture is not being drafted in. Also if no one has mentioned it consider removable loc-tite on the reed screws. I was very pleased with the improvement on my Optimax.
Discussion Starter · #16 ·
I will let you guys know about the results, when I break from this weather. I think I may see some improvement due to the reeds that were in the block were lifted and worn out. I was actually able to get the engine to idle at a lower RPM and without having to reprime it. (not saying they were related by any stretch).
Already done!
Had hydro tec kit + block ported
I had nearly the same motor n had great performance enhancements. Also had exhaust tuner, exhaust ported, carbs venturied n jetted.
Discussion Starter · #18 · (Edited)
I finally had a chance to run it this morning and it felt strong! It popped right on plane! This is still with an older block. Haven't gotten the new power head back in.
Glad to hear you think you are seeing performance improvements. I definitely saw smoother idle and more predictable acceleration through the power band.
Reactions: flyclimber
1 - 20 of 23 Posts
