Today I got a chance to run the Bohemian 17 for the first time. We borrowed a motor. Wasn’t the best one on the block but it was the best deal for what we needed. We wanted to see if the hull was going to do anything weird once the power was on it. It’s really interesting seeing a completely new hull design come onto the market and testing it.
The motor we got was a 1988 Mariner 60. It came with the stock aluminum prop 10 ¾ x 15 w/ 0 cup. It was a mechanical steer so we rigged a side console. We had 100lbs of sand in the front still where the gas tank would go. It also had what we needed to make the motor run, batter, 4 gallons of gas. Also had me and another 200lb person. It ran ok, but once we started doing speed runs it would over heat and power down. We didn’t get all the runs in that I wanted but I did get to run it through the paces. We did get enough runs in to get some stats and a short performance report.
I started out running the boat with me and one other 200lb person. With no trim tabs on a skiff I was kind of timid about throwing the throttle all the way down. I trimmed the motor all the way down and rolled onto the throttle. It popped up on plane with no real issues. I slowed back down and threw the throttle down and she popped up in a boat length and a half. Not bad for a stock prop. This being an older 2 stroke motor it was very happy in the higher RPM’s. Once up and running I had Dave slide more to the middle of the hull and the boat leveled out nice. Cruse speed at 3800 to 4200rpm was 25.5 and 29 mph. Not bad for a 17 ft skiff. At 5k she was doing 36mph. That’s amazing because the other skiffs I have been in before maxed out at this speed. I put the throttle down and trimmed the motor up just a hair. She gets on the running pad like a dream. She felt like a ballerina tip toeing on the top of the chop. Anyone that runs a V bottom boat with a running pad knows what I am talking about. The prop spun up to 5600 and we got 42.6mph. There was no hull “sticking” that is typical with flat bottom boats. You just simply trim it up a hair and you’re on the pad. The prop was pretty close to where it should be for 2 people. The problem was when running the boat you would trim up the motor and it would not porpoise. You could trim the motor all the way up until it completely blew out and you would have to back off the throttle to make it hook up again.
We ran the beach from Longboat Pass to Big Pass. The boat was great on the beach in the rollers. It was very predictable in the pass with a strong outgoing tide. The boat rode the waves like a bay boat, nice and wide.
I had a quick chance to run the boat by myself. The motor kept on over heating and shutting down. I went to run it real quick to see if it would do the same for me before I started taking running shots of the boat. Running the motor by myself it was noticeably different. The motor wanted to spin right to 6k without hesitation. This is a good sign the prop was not the right size. I trimmed it up to make a speed pass and it revved to 6k again. My GPS did not show that I was going any faster so I trimmed it up a hair and the prop blew out again. I ran it back to the beach and set up for my shots.
It is a weekday so there was not that much boat traffic. I ran some figure 8’s to get a feel of the handling. The boat turned flat and was predictable in the turn. The hull did not want to skip or spin out. The air coming from the step hull was not an issue. The V bottom really holds it in place.
Here are a couple pictures from today.
Real pic of the bow flair
And last, but most important
-Richard
-Richard
