http://tampa.craigslist.org/hil/boa/948942756.html
Anyone know if the above motor could be beefed up to a 15 or more reliably? And is it really that easy to change it to short shaft?
It looks like it may be easy to change the shaft length with a new 15" vertical driveshaft and water tube.
The parts list shows different carbs, but I'm not sure about any other differences there may be.
http://shop2.evinrude.com/ext/index.aspx?s1=6eb148943f8f19ace8a624a3f17fe772
NADA lists it at 114 lbs for the 20" shaft, a bit heavy for 10hp, but not a bad price I guess.
*edit* I thought that link might take you right to it, but it didn't work.  pick a 1998 E10F... model.
Discussion Starter #3
Don't want to jump to any conclusions but looks like it might just be a simple carb change. How quick would that push a LT15? What about an LT25? Considering those two by next summer.
Won "Do More With Less" Award!
U are looking at 9.9hp evinrude HIGH THRUST 4-stroke motor, that motor is designed to push heavy boat with more trust. It's like a 9.9hp evinrude with 25hp lower unit with prop, so u are looking at wrong motor again....lol. Just look for regular 9.9-25hp 2-stroke or 4-stroke tiller model without powerthrust or high thrust.
9.9hp evinrude highthrust wil push u 15mph instead 20 mph with 9.9hp without highthrust.
15" or 20" shaft motor will fit all LT 15 or 25.
My 2 cents.
whitesnooky you're a dream crusher :'(
How's you're new LT coming?
Don't worry....there's plenty of motors out there with better deal and newer motor.
There's plenty of time for it.....don't rush.
I love it! Keep it light and simple........I'm going to hang 25hp yamaha 2-stroke when the electric jackplate comes in about 4 to 5 month depend on the build.
I have a new 2003 yamaha 15hp 2-stroke for sale with carbon marine tillerpiller and tinytach...only 22 hours on the motor......a great deal!
