1 - 11 of 11 Posts
I have a trailer for a 16ft boat and it came with those cheap black plastic bearing covers. You know...the ones that slide over then fall off while youre driving. My question is are they really that important? My friend doesnt use them and says not to worry. The grease is still in there and other than slinging out while driving its not really a problem. Thanks.
I've never had mine fall off. I used alittle grease on them to keep them stuck in place. You can go without them, but I like my grease fittings clean.
I figured I should keep them on. I saw some that came with metal and the plastic cap. Not sure what the metal cap is for. If you can guess I am not an experience boat/trailer guy and Im learning about this as I go. My boat is good to go. Just trying to figure the trailer out. Thanks.
1652 G3, & 1756 Lowe tinnys
Google "bearing buddy"   I have them on my trailer. Allows me to easily grease the bearings. Some people love them...a few hate them.  rich
love your bearings and they will love you back.
your friend is only been lucky so far.
I would suggest an rainy afternoon googling boat trailer bearings, they need good maintenance.
Ok so I checked them out. They are bearing buddies I believe. Picture posted below. Now I just need to borrow a grease gun and make sure they are full of lube. Thanks for all the help.
Yep bearing budding. You can buy the caps cheap. Just measure the diameter for the right size. The most common is the 19B cap. If you remove the bearing buddy check to see if you have a zerk fitting on the axle. If you do get rid of those and use it. Otherwise your on the money.
1 - 11 of 11 Posts
