1 - 20 of 30 Posts
Discussion Starter · #10 · (Edited)
Vehicle Boat Automotive exterior Watercraft Sailing
I used to ease the boat with d gig, drifting with d tide n some poling as well. So u think d flounder will hall arse wit d trolling motor? Really have not used it to flounder yet... Also my trolling motor bracket is fixed n welded. Forgot to mention, since I retired no-one else can flounder on weeknights n so I usually go solo n so that is with out some one on d push pole.
Zephyr Cove is on FIRE!
To be very honest, a trolling motor needs way more water to run as quiet as is can than you can usually spot a flounder on bottom. I’ve been floundering in boats and on foot for over 30 years and have done a ton of R&D on flounder lights as well. You already know my stance on trolling motors used to try to sight cast fish in water that people should be either wading or poling. Same goes for gigging.
We used to gig with home made gigs and single mantle Coleman lanterns full of Unleaded gasoline and you had to pump them up with a little thumb screw that had a vent hole in the middle so you’d have to quickly use your thumb as a check valve to pressure up the tank. Tin foil on the back of the globe for a reflector, a coat hanger and piece of water hose for a handle and we lit them with matches. Those were the times man. My father had me by his side gigging around 5 years old.
Never had to use a pump up lantern but we did use the foil on the back and duct taped the hanger to make a handle that wouldn’t get too hot.
Smack daddy has some good advice. In my experience, I either go all out halogens with a generator poling or fan, or walk with a Coleman lantern and single spear gig.
LED’s suck as a flounder lights but if you do use a trolling motor, spray paint it black bro.
My all time record gigging was walking in pairs with a Coleman.
Green or warm white LEDs kick ass. I won’t use a loud ass generator or hot PITA lantern again. I’ve gigged hundreds of flounder with the Eclipse LEDs wading. Halogens are still good, I won’t knock them but LEDs outperform them with efficiency, weight, longevity and they just work very well.
First flattie was in knee deep water, all of these were gigged using LEDs. I designed an aluminum housing for Oznium using their 10,20 and 50 watt Eclipse chip so you can easily DIY light setups and thread them on 1” PVC threads. They also make great hog hunting lights for feeders.
Green Blue Light Red Yellow
Fish Fish Flatfish Flounder Seafood
Green Light Lighting Technology Laser
Flatfish
Flatfish Turtle
Cuisine Dish
Turtle Flatfish Fish Flounder Pond turtle
That’s pretty impressive man, never saw the green floundering. Looks good.
It’s all about the spectrum. Green and yellow penetrate water the best. The reason lots of people have the wrong impression when it comes to LEDs and how well they penetrate water is either because they only think of the super white cool white or they tried using them above water or both. Halogens work well because they are more yellow and the light penetrates the water with less glare. The same goes for green and under water. The yellows and greens don’t reflect back off the particles in the water and give a clouding effect like cool white will. I like green for super clear and a little iff color water and warm white for the murkier stuff.
1 - 20 of 30 Posts
