Here’s my take. I’ve had all 3 (Three) Types.
Bobs regular hydraulic JP
Bobs ActionJac JP
Atlas JP (Not Atlas Micro)
They all have their pluses and minuses.
Pros:
-No electrical items hanging off the transom.
-a little less weight off the transom
-it’s faster, quieter and strong.
Cons:
-Have to grease it
-Must have room to mount the auxiliary pump somewhere
Bobs ActionJac
Pros:
-All one unit
-No auxiliary pump
-Fast and strong
Cons:
-Has to be greased
-Pump is all one unit and sits in the water
Atlas JP (Not Micro)
Pros:
-Greaseless slides
-It has the ability to convert between 4-12” of setback by using their extension brackets
-No auxiliary pump
Cons:
-Pump is all in one unit and sits in the water
-It’s slower and SOMETIMES struggles to lift my motor while running hard or coming on plane (Mind you, my boat is 22’ long and has a 505lb 250HP motor)
-I’ve read that it doesn’t have a full 6” of travel (I’ve never measured)
The reasoning I mention the greasing as a con is two fold. 1, I hate grease. A drop of grease seems to spread everywhere on a boat. And 2, sometimes you can’t get to the grease zerks depending on what boat it is or what accessories. Are there powerpoles mounted to the jackplate side via brackets? This could hinder being able to get to the grease zerks. Is it a sponson boat that you can’t get a grease gun to?
The greaseless slides is the reason I use the Atlas jackplate now and it really the only reason I have it on my new boat vs my older boats with Bobs.
I think all are fine products.
-Andy
