I've seen some fleeting discussions on this issue and its commonality, but would like to re-start the flame and try and get it all laying flat.
I just purchased a Maverick HPX-S with an Atlas Micro jack Plate. The seller warned me that the Micro has a tendency to lean to one side or the other and get a little sticky (shutter) on the travel up. Non-existent issue on the travel down as gravity helps lower the motor.
I've researched Atlas's recommendation on maintenance of their "ATLAS" (which has very pronounced rods) in regards to Dawn dish soap, but it's a little less clear as the Micro's drive rod is housed in a close-out area deeper in the plate, and much less pronounced.
1. Has anyone seen this issue and mitigated it?
2. Do we believe this issue is more influenced by debris internal to the drive rod or the side nuts that rubs against the slot as the plate actuates?
3. It also appears the drive rod actuator is not centered in the plate, contrary to their ATLAS model. Do we think this offset provides the "lean" as one side of the plate has a larger actuation force than the other? Is this "lean" just a product of the design and can't really be mitigated?
Some of my ideas to mitigate this issue are:
Grease the Nut/Bolts in the slot to decrease friction
Replace the phenolic washer in between the Nut and Micro slot to decrease friction
Spray the drive rod, slot bores and faying surface of the nut/washer with silicone
Adjust the torque on the fixed nuts (not my first choice)
Any help/recommendations are much appreciated!
