1 - 8 of 8 Posts
904 Redfish
Was going to use Jb but herd mixed reviews on it people have told me if you don't keep good paint on it it corrodes
Yeah, JBWeld has steel powder mixed into the epoxy as a filler.
If it isn't primed and painted it will develop rust spots.
An alternative if you are worried about possible rust dots
is an aluminum powder filled epoxy like those offered by http://www.hypoxy.com/
Also important to remember to chamfer the top and bottom of the hole being repaired
so the chamfers act as locking tabs, when filled with the epoxy putty.
If I remember correctly Marine Tex used to have a display at boat shows where they'd used the stuff to repair an engine block... I wouldnt' hesitate to use in for your purpose... If you're hesitant, just do a small spot and see what results you get. I'd use the gray color instead of white (if they still make it...).
I used a two part thickened marine epoxy. I put tape on one end of the hole so it would cure smooth and level and sanded the other side.
BE THE LURE
I used it on a metal bath tub that was white. It covered a very large hole in the tub, I puttied it up, sanded it down and it looked great.
1 - 8 of 8 Posts
