1 - 20 of 28 Posts
Anyone use these LED products?
http://www.oznium.com/marine-led-lighting
I was thinking about using some of the 4 chip LED's
http://www.oznium.com/marine-led-floodlight
I was thinking about putting one in the livewell, and one on each side of the center box for when it gets dark. Not sure if I will go with blue, or aqua, or white. Whay do you guys think?
Cert. Yamaha technician
Dang, cant argue that price.. Someone on here made some nav lights out of them for a gheenoe. It looked good. I think it was caucasian sensation...
They are definately cheap enough, but I'm not sure they would be legal for nav lights since they aren't USCG approved and don't have the stamp.
Never said I was going to use them for Nav lights. 1 for the livewell below the water line, and 1 on each side of the box to light up the floor a bit. Just wanted to hear from someone who may have used them.
Discussion Starter · #9 ·
Well I have decided that I will go with the 4 chip LED's, now the question is what color?
I was going to do blue everywhere, but now I'm reconsidering. When night fishing, will red LED's really not effect my night vision? I have a seperate thread going for the livewell. I hope to get an answer soon so I can order.
FC, check the lumen output of the different colors, they have a chart on their site. This will help you decide which color is better for not losing night vision.
I'm running some of their products, the blue and red flexible LED strips are good. Also the little 1 watt spot and floods are incredibly bright and small. Don't know about the others.
The products are priced right, and I've not had ANY issues with their stuff. Seems to be good.
Under the deck the blue is pretty cool, but I think still messes with my night vision a bit for overhead use. I'm using red under the console and am happy. It doesn't look as cool as the blue for under the gunnel use though IMHO.
The flexible LED strips are easy to hide under a storage area lip, very small, and you can simply put them on with a screw-on zip tie. Very easy install and out of the way, and installing them under the lip means no light coming back at your eyes so it's easier to see down into the storage area.
A 4" strip would be bright enough for a 3' wide storage area. Any bigger I'd probably go with one on each end.
I think you'll be really pleased with any of their products.
Tom I've been trying to find the chart but can't seem to locate it. I think I'm pretty sold on the Blue 4 chip lights, but just a few of them. I'll order a few and see how bright they are. Worst case I can send them back and get new ones, or I'll just wire them into a really nice flashlight ;)
They seem like a great little product, and at $4 a piece I can play all I want. Ordering now :)
Blue is very bright, and can mess up your night vision really easily.  Think about being pulled over by the fuzz at night, those things will get your attention.  I don't have any experience with the white running lights.  However, I hear helicopter pilots use red for more friendly vision.  I used red on the marsh hopper and they are pretty easy on the eyes.  When I was in high school, I used a green plastic bag and turned the interior lights of the jeep aqua.  The lights are still aqua after like 9 years.
Discussion Starter · #13 ·
I've done quite a bit of research on this so far, here is a link to the other topic where I outlined my findings.
http://www.microskiff.com/cgi-bin/yabb2/YaBB.pl?num=1303148212
Basically is it's dim light red is the best, if it's brighter light then blue or green are the best and easier on your eyes. The only reason the cops still use blue is to seperate themselves from other emergency vehicles, there was a study done that showed bright red lights actually are better attension getters, but since not many people will pull over for a fire truck or ambulance it was best to still have the blue lights. If you notice though alot of the newer light bars have more red lights then blue for that reason.
Alot of aircrafts did use dim red lights in the past, but when looking at a chart anything on red is now unreadable. I've been in 2 smaller Robinson helicopters recently, one had a dimmer white light, and the other had a fairly bright green light in the pit.
Of coarse this all depends on the lumen output, anything too bright will mess up your night vision for a while, but it seems green is the best followed by blue for what I want.
Discussion Starter · #15 ·
Went with blue since the hull color is light blue. They should be in today, but won't be installed for atleast a few weeks, and you know there will be pics ;)
Discussion Starter · #20 ·
I went with blue, they are cheap, but very bright and I think will do the job beautifully. I will most likely make another order in the future.
1 - 20 of 28 Posts
