Ankona Shadowcast 18 center console loaded
Discussion in 'Microskiffs For Sale' started by LifeOnFly, Dec 1, 2017.
  1. LifeOnFly
    LifeOnFly Active Member
    42
    18
    33
    Boat is located in Boca raton fl Contact Michael at 5618569165 asking 17k
    2015 Ankona shadow cast 18
    center console with jump seat insulated cooler underneath.
    *length overall is about 21 ft 2 inches sitting on trailer *
    fits in my garage straight back with about a foot to spare.
    -2015 30 hp tohatsu power tilt and trim upgraded 4 blade power tech s.s prop (under 100 hours) (have original prop brand new for spare if ever needed)
    -2017 riptide 55lb copilot with quick release bracket less then a month old! (have receipt)
    brand new deep cycle group 31 115 amp hour battery bought less then a month ago
    professionally wired in with correct breaker and hardware
    -2 stainless steel rod holders mounted on starboard side of center console
    -navigation lights + under gunwale blue lighting
    -Garmin 50s chirp with navionics depth finder hooked up
    -Powerpole Micro with 8 ft sticket pole
    -21 ft moonlighter carbon fiber push pole
    -2015 aluminum float on trailer with led lights and break away tongue+spare tire and hub
    -Bow bulkhead mounted marine spearks with usb and auxiliary
  2. DocHoliday
    DocHoliday Well-Known Member
    3
    I am interested in your boat.Mine was totaled in the hurricane.If possible can you send pictures to my email cchinc@gmail.com.If you nave a better picture of the tunnel and the "power pole" I would appreciate that as well.I am in Texas.I don't want to wait for the lead time and I will have to pick upi the boat in Florida anyway If I have one build.
    Brad
  3. LifeOnFly
    42
    18
    33
    Says your email is invalid, can get you pictures tomorrow morning.
    Lot of people interested and called but bump as well.
  4. thepatten
    thepatten Well-Known Member
    19
    30
    48
    If you're clicking on the email link in his post you'll need to remove the ".If" at the end as I think he forgot the space before the next sentence. Maybe you knew that already but just noticed and wanted to post just in case.
  5. LifeOnFly
    42
    18
    33
    Wow thanks for that appreciate it..
