Probably the carb or filter. Check the filter first and then pull the line feeding the carb. Use the main fuel line primer bulb to make sure there is no line blockage. Chase down blockage if that is what it is (I always suspect a bad primer bulb if the filter checks out). If not buy an OEM service manual, yes I know they cost more but you get what you pay for here. Marineengine.com has many reprints of out of print manuals at a reasonable price (YMMV). Clean carb. The vast majority of the time you won't need to replace anything in the carb. These carbs are simple, usually a fixed main jet and only an adjustable low speed needle valve and/or idle. Just pay real close attention to how it comes apart and before you pull any needle valves count how many turns (by 1/4 or 18th of a turn) it takes till the needle gently bumps the seat. Don't crank it shut, you can cause damage if you do. You will reverse that to get the same adjustment when you reassemble the carb. Clean every hole, nook, and cranny with carb cleaner (watch your eyes for spray). I really prefer the flammable, bad for you, environmentally unfriendly stuff. I hate the new "safer" versions. Reassemble and reinstall. If you still have the same issue then you probably need to rebuild the fuel pump (but you will have a nice clean carb!). When you dismantle it check the diaphragms for flexibility. Stiff or "crinkly" diaphragms are a give away. Be careful if you dismantle the fuel pump, some of them have spring assemblies in them and not only can they go flying, but they need to be reassembled exactly the same way (there may be more than one way if you shift diaphragm orientation). They can be tricky if you don't pay attention. Take notes or better yet pictures. FYI OEM fuel pumps are sometimes replacement items, after market rebuild kits may exist at a considerable cost savings. Example, I just bought a rebuild kit (Sierra?) for a '70 6hp at $12-$13. Evinrude wanted $60 for an assembly. That was a no brainer.
Oh another word of advice, use the proper size screw drivers that are in proper shape (not undersized, dull or broken) when working on the carb. Especially when pulling valve seats or jets. Tools in good repair can save you some serious headaches here. A stripped or broken main jet sucks.
I'm not sure how safe Seafoam is to use uncut with fuel(no idea). I use an old pump oilier filled with fuel/oil mix when I test engines.
YMMV. Don't stress, enjoy doing it yourself.
Swamp
ETA: If you do get a manual and/or get a carb rebuild kit, they may talk about or include plugs and or lead shot. Unless the carb is so bad that it needs a COMPLETE rebuild there is no need to pry lead shot or any semi permanent plugs. Usually when things get that bad it's time for a new carb anyway. On the other hand you have nothing to loose at that time either strip it down and soak it in carb cleaner for a few days. Over the years I've only come across a very few carbs that where that far gone and even fewer that could still be salvaged. IMO
