I think it’s the acronym for never mind. He must have found the other thread...What’s NM? No more. Go to store and they will order it.
This....at the time I was wondering if stainless and tinned copper were compatible, but I found the answerI think it’s the acronym for never mind. He must have found the other thread...
Most of the stores can order them and have them in a day or two. I’m about to get another one because the single can’t handle running my Lowrance while the motor is not running.
$40 for more heavy battery cables or just link the batteries with $2 worth of copper flat bar...more Ah. I can rope start my outboard if I have to and it will charge the batteries back up in ten minutes.yeah, I ordered some from them yesterday--their prices blow everyone out of the water.
Out of curiosity, why wouldnt you hook both of them up to a Perko switch?
Copper flat bar will connect the batteries in parallel then?I’m going to mount another one right next to this one and use a copper flat bar to link the terminals so I can run my GPS and a couple accessories...
I got my cables made up in custom lengths from this site-
https://tinnedmarinewire.com/wire/
Sí síCopper flat bar will connect the batteries in parallel then?
One more idiotic question: I assume you bolt the terminal to the battery w/ a M6-1 bolt; are you backing this w/ a wingnut, nylock, nut/lockwasher or what? I'm playing hell finding these metric sizes in stainless$40 for more heavy battery cables or just link the batteries with $2 worth of copper flat bar...more Ah. I can rope start my outboard if I have to and it will charge the batteries back up in ten minutes.
I found stainless M6 phillips bolts at Lowe’s that fit great. I will use a lock washer.One more idiotic question: I assume you bolt the terminal to the battery w/ a M6-1 bolt; are you backing this w/ a wingnut, nylock, nut/lockwasher or what? I'm playing hell finding these metric sizes in stainless
That should work, I will email you. Thanks!Smack. Worst case if you could purchase and have it held at Cocoa I could pick it up next week Thursday Friday. Or latest week after.
