I have a 1999 Johnson 40hp (40rleea) pull start. Its has mounting spot for starter. Should I be looking for a matching starters to the same motor with a starter or the starter that will match the flywheel?
Reason is they are 2 different starters. If I run a parts search on the current flywheel ill find same Johnson motors with a starter. But same motor with starter is a totally different starter!
