1 - 20 of 24 Posts
This is the first motor I have owned with this knob. Read the Merc manual as far as using it (starting procedure). Is it basically, pull to choke and a fast idle when you turn it open (clockwise)? I assume this is to help the engine warm up, right? Do i need to turn it back down before opening up the throttle?
Thanks,
TRW
not really, all that knob does is bump the idle up a hair. it's possible that motor could use an idle adjustment anyways
Thanks,
TRW
Like SB said, its just adjusts the throttle a hair. I would say if it sounds like its idling high, turn it back down. Also be aware that the choke on that motor is a pump to choke, if you look closer, all the choke knob does is push down a built in primer pump.
Good luck with your motor!
Pretty much what I thought. Thanks guys.
TRW
Wait. comeback!
I'm not near my motor to check but I think it also advances the timing. I don't know if it would damage the motor running it like that but you never know
Wait. comeback!
that advanced timing rod is a joke :eek:, i've run the piss out of these motors without one ( timing advance linkage) if your motor sounds like its wanting to die out while idleing on the water hose just bump the adjustment screw under the cowling and you'll be good to go :cool:
The only problem I've had is the motor will "bog down" and die every once in a while when I open the throttle quickly. Seem like it floods out. It seems like this happens less frequently if the knob is "open" part way. Other than that it runs like a top.
Someone else suggested this could be a timing issue. I think it's fuel/carb related. Any suggestions?
TRW
WHILE WERE AT it how in the %^&* do you set the timing and why do these motors buck just above idle ... Dave
never messed with the timing on mine as i never needed to but that timing advance linkage has a lot of slop to it so i cant really say whether they're really all that effective or not :-/ mine will bog a little sometimes also just feed it slow and steady till she perks up then lite your candles ;) :cool:
Think I figured out the bogging problem: My exhaust dips below the water coming out of the hole. The extra back pressure is causing the problem. If I trim the motor up a bit, she spins right up. :)
PS- Found a new school of fish during testing this afternoon :cool:
Not that it is...but it could also be running a little rich. If you have fixed your issues ignore, if it continues to be a problem then:
There is a fuel/ air mixture screw located on the carb in the front of the motor. It is the one located above the primer knob by maybe 2" and has it's own access hole through the air shield. Anyway, if you are idling rough or bogging, it might need to have an adjustment(please only adjust if necessary- a motor that runs rich is better than one that runs lean when it comes to the life of the motor).
Adjustment:
After proper idle speed adjustment. Start the engine, put it in gear at idle. Adjust the mixture screw counterclockwise until it misfires(due to being too rich). Then count the turns while adjusting it clockwise till it once again misfires(this time too lean). Divide the turns you counted by 2 and turn the screw counterclockwise to find the happy medium. Too rich is better than too lean.
I am not an outboard mechanic and do not claim to be, but having the same issue with a 25hp carb I installed on my 20hp, this cleared it up. The information was a summary of what was written in a manual I used to tune the new carb- worked great.
Discussion Starter · #13 ·
Thanks. Plan on fishing pretty hard this weekend so if the problem persists I may give that a shot.
TRW
Discussion Starter · #17 ·
Re: 99 25hp Merc Primer knob UPDATE
Went ahead and leaned her out a tiny bit. Results were no more bogging in the hole shot, smoother idle, and I swear it starts even easier than before. Thanks for the suggestion.
so how abouts did you get to running lean? did you just mix the oil lean or an adjustment on the carb ? the leaner you run it the hotter she's gonna run just dont want to scorch a piston :( but if you can find her sweet spot you should be good to go ;)
Discussion Starter · #20 ·
I did the adjustment suggested by Wannabe'. Wound up with the adjustment screw about an 1/8 of a turn closer to the lean side. Still running standard mix on the oil/gas.
I'm no mechanic so now you guys got me worried. :-/
Am I in danger of damaging the motor?
1 - 20 of 24 Posts
