1 - 9 of 9 Posts
Bought a 98 Johnson 9.9 that looks like new, barely used.  After running a little rough at first, now runs great, but leaking a greyish sludge from prop.  Mechanic did pressure test-fine, compression test-good, and cleaned out carburetor but leak continues.  Also checked gear lube which was a little dark but found no water.  Leak is a slow drip that smells like gasoline.  Any engine pros out there have any ideas?
Unburnt 2 stroke oil and gasoline mixed with carbon
   deposited on the walls of the exhaust housing
continues to trickle down after the engine is put away
             normal with a 2 stroke motor
thats what it sounds like to me also :cool:
It definitely doesn't look like that. It's a slight drip and sounds like from the replies it may not be anything to worry about. Thanks for all the help from a newbie boat owner.
Taylor
The world is flat....and shallow.
If someone before you ran something through it to "de-carbonize" it, it will do this for the next 8 - 15 uses. If that's the case, it's normal. Any way you can find out if that was done?
Kemo :cool:
Discussion Starter · #9 ·
That's exactly what the mechanic said when I picked it up yesterday. He said it looks and runs like it's new and the best thing is probably just to run it like crazy and let the exhaust system clean all that out. That was good news as I had read elsewhere that grey fluid meant lower unit problem. Thanks again for the replies.
1 - 9 of 9 Posts
