I don’t see the love for 115hp on a small boat unless you’re a poon tournament fisherman or rarely pole.
It sounds like poling with a 115 is a bit much. I’m thinking sticking with the light 90 2 stroke or upgrading to 70/90 four stroke.I don’t see the love for 115hp on a small boat unless you’re a poon tournament fisherman or rarely pole.
Depends how happy hour is…? I will be fishing shallow 90% of the time….I think the 115 is a bit excessive for what I’ll be doing. Unless someone said the 115 doesn’t make that much of a weight difference for poling or draftI'm happy with the F70 on mine and would not go bigger due to draft concerns as I am in Texas. I was able to hit 40 - 41 MPH with two people and a light load before switching to a Foreman prop, but the holeshot wasn't great when loaded down with three people.
How fast/shallow are you trying to booze cruise with four people on board anyways?
Fair point, I’m 215 lbs and will definitely have a trolling motor for the days when it’s blowing 20mph. The extra 35lbs seems worth it for another 15 hp I’d thinkTake this with a grain of salt because I don’t have a ton of experience on the pole. I’ve poled a couple HPXs, @DBStoots waterman with 70, and my Evo with 115. You can definitely feel the difference but to me it wasn’t a huge deal but I don’t pole a ton. I’m also a big dude over 200 so not sure if that makes a difference. Dave’s boat was the easiest it’s pretty nimble but I feel my Evo poles just fine. Tracks good and was not difficult to push around. I guess as I spend more time out there I’ll start to appreciate those subtleties. For now I’m a part time poler so I’ll keep the extra ponies. It was only 35lbs more than the Zuke 90 I was considering and I’m more than happy with my choice.
25hp***Fair point, I’m 215 lbs and will definitely have a trolling motor for the days when it’s blowing 20mph. The extra 35lbs seems worth it for another 15 hp I’d think
Yea kind of where I’m at , the 10-30lb differences probably won’t show to me, also the standard 115 mercury is 1k cheaper and no wait time as opposed to the xps here in sw fl 🤔Just looked up specs Suzuki 90 is 344lbs and proxs 115 is 359lbs doubt you’ll ever notice 15lbs
True. The only other feature that favors the Suzuki is the offset drive shaft, which positions the center of gravity closer to the transom. I may be splitting hairs here, but it does make a difference - even if just a small amount of weight forward.Just looked up specs Suzuki 90 is 344lbs and proxs 115 is 359lbs doubt you’ll ever notice 15lbs
It seems every Suzuki is order only around here and I’ve hear 3-80weeks. Same with proxsTrue. The only other feature that favors the Suzuki is the offset drive shaft, which positions the center of gravity closer to the transom. I may be splitting hairs here, but it does make a difference - even if just a small amount of weight forward.
Three weeks to almost seven years, that’s a hell of a time estimate!It seems every Suzuki is order only around here and I’ve hear 3-80weeks. Same with proxs
WTF? Are you ordering those engines from the cable company?😳It seems every Suzuki is order only around here and I’ve hear 3-80weeks. Same with proxs
Now is not a good time to buy motors, with high demand and a supply shortage. However, you have an open offer of help from @JacobCayo on this thread. Boat builders get top priority on new motor availability. There are new motors around if you take the time to search:It seems every Suzuki is order only around here and I’ve hear 3-80weeks. Same with proxs
The difference in weight and price for the extra horses seems like a no brainerHaha still going. I’ll add some more. Went fishing with my dad yesterday and he thought I was crazy for going with the 115 saying the Zuke 90 was good enough. Opened her up going across a slick calm bay and he looked at me, smiled and said now I understand 😄
