cherokee boats fla
i bought a 1968 kiekhaefer mercury 200 20hp for my cherokee. its in really good shape but hasnt been used in 10 years and the steering is siezed. its a tiller motor, so how do you free the steering? also how do you separate the middle of the outboard to get to the shifter? because its alittle stiff and needs to be greased (right before the lower unit) right now the block and lower unit is off the motor.
thanks
angelo
Use a 50/50 mix of aft and acetone and dribble it on the stuck parts. Keep at it and it will penetrate, not a squirt and done project.
cherokee boats fla
Discussion Starter #3
its the entire steering. were would i put it? take out the grease zerk?
cherokee boats fla
Discussion Starter #6
I think im going to have to buy this
http://m.ebay.com/itm/Swivel-Tilt-Exhaust-Mercury-outboard-200-20-HP-others-SN4061539-1977-Write-/201300699813?nav=SEARCH
I dont think the steerings going to get free
cherokee boats fla
Discussion Starter #7
i got the steering free. the stop switch was bad i had to replace it. i got a universal kill switch. it has 4 pins, should it be wired so on "on" the switch is open or closed? and can anyone tell me what order the diaphragms go? theres 4
thanks
