60HP Yamaha 2 stroke modifications
Discussion in 'Outboard Maintenance' started by kingofsea, Mar 27, 2017.
  1. kingofsea
    kingofsea Active Member
    10
    4
    28
    Has anyone out there done any work/modifications on a 60HP 2 stroke Yamaha(2004)? I found a website out there called Hydrotec Marine Performance that sells big carbs, Exhaust tuner, fuel jets, and all gaskets needed to take your 60HP to around 80HP.
    Anyone ever done this? Just wondering?
    flysalt060 likes this.
  2. firecat1981
    firecat1981 BBA Counselor
    5,261
    424
    2,288
    The general consensus over the years here have been don't do it. Adding more power then what they were designed for with lead to you buying a new motor a lot sooner.
  3. kingofsea
    10
    4
    28
    Got it. Thanks for the heads up.. I always wondered about it, and if it would even be worth it.
  4. firecat1981
    5,261
    424
    2,288
    Only you can decide that. I'll just say this, there might be a reason the 70hp is a seperated class.
  5. kingofsea
    10
    4
    28
    Thanks for your help! Would rather have the relaibility than speed.
    firecat1981 likes this.
  6. No Bait / Lures Only
    No Bait / Lures Only I Love microskiff.com!
    794
    120
    418
    Yes I currently have 2 motors modified with Hydrotec parts, built 90>115 1987 on Hoog 16'8" and still in service, built 25>35 2006 currently on 17'6" Spear Glade X, run it 3-4 days per week. No issues at all with longevity or reliability. In addition the modded motors burn less fuel as the cruise speed is substantially higher than stock. Only downside is they require premium fuel vs regular for top performance. In addition I have a 18' Shipoke with a lightly modded Mercury 2.5 EFI 150 exhaust tuner, solid mounts, carbon fiber reeds. Runs great no premium fuel as no head modifications. All my motors are modded and no issues....
  7. RunningOnEmpty
    RunningOnEmpty I Love microskiff.com!
    681
    214
    168
    I did a hydro tec style modded yamaha. It was a fun project and fast. Probably won't do it again though. Buying a bigger motor is so much easier!
  8. No Bait / Lures Only
    794
    120
    418
    You sounded disappointed, what motor did you modify?
  9. KnotHome
    KnotHome "I got to stop wishin'. I've got to go fishin
    471
    75
    403
    The only difference in the 60 and 70 are the carbs. Wouldn't hurt to change those.
    No Bait / Lures Only likes this.
  10. No Bait / Lures Only
    794
    120
    418
    Hydrotec modifies the bore of the carbs and the jets, not just a stock carb. Since 1990 I have had good experiences with their products. Company was Yamaha Rebuild/Warranty Center, and so lots of experience with stock and racing motors as well.
  11. kingofsea
    10
    4
    28
    Thanks guys!! really appreciate all the input!
  12. RunningOnEmpty
    681
    214
    168
    I wasn't disappointed at all. I had the 3 cylinder 30hp and it was almost as fast as the yamaha 50hp that replaced it. I will say that the 50hp had a much better gear case and the prop shaft size difference is huge. The little 30hp has a wimpy lower that's very fragile with a modded motor. The 50hp also gave me confidence to explore because it was stock and it turned less rpm's.
  13. No Bait / Lures Only
    794
    120
    418
    Still have the 50? If so you left it stock? Only drawback to the 25/30 lower unit is the delicate prop shaft, had to have mine straightened........cypress stumps are tougher.....
  14. RunningOnEmpty
    681
    214
    168
    I straightened my 30 shaft 2 times. I kept the 50hp factory and only ran it a few times before selling it to a fellow forum member. Now I'm running a yamaha 200 hpdi while searching for a 250 or 300.
  15. nativejax
    nativejax Well-Known Member
    173
    110
    718
    If you were going to mod a yamaha with anything, the hydrotech boys are the ones to use. Lots of guys in the bass world use them and I dont recall them having any more issues than what just normally can occur with a stock motor.
  16. No Bait / Lures Only
    794
    120
    418
    Surly you are looking for a 2 stroke ? Rightttttt
  17. RunningOnEmpty
    681
    214
    168
    I think I'm gonna stick with another yamaha hpdi vmax or a mercury optimax xs. I still love my 2 strokes.
  18. ABoykin
    ABoykin I Love microskiff.com!
    103
    68
    103
    The guys in Australia do it! Man I wish I could give these guys a call just to see how much HP they are getting out of these motors!
  19. No Bait / Lures Only
    794
    120
    418
    The motor of choice for racing is the 2.5 merc v6 as lots of them around to build up. Currently my shipoke 18 has a stock 1997 efi 2.5 merc and it tops 60 gps with a 4 blade prop. Still a little more speed with a 3 blade, handles good with the 4 blade.
  20. RunningOnEmpty
    681
    214
    168
    My 21 redfisher is setup with 5 batteries. I have no regrets on buying the 36v trolling though. I'm topping out at 50 mph while turning 5700 with a 2.6 200 hpdi 21 pitch power tech 3 blade. My cupping is worn down and my motor is cavitating. Have you ever tried a solas hr titan prop? I can get a 4 blade for under $300. I'm not looking into spending a bunch for a prop if I'm thinking about a bigger motor.
