Using a single battery as a starting battery and trolling motor battery, will an attached (at the battery) 60 amp resettable fuse kick off while starting?
NO. This is a parallel circuit it will not drag amperage from the starter to the tm.
Thread Killer
there are some pretty small AGM batteries that will run that motor, if you wanted to get another battery for cranking
