I’ve been designing my own
5m aluminium skiff to run 40hp. I’m looking for opinions from anyone with building skiff knowledge. This model Is 3D printed and painted 1/20 scale. I need the bow sitting a little higher in the water. If I change the sides from 25 degrees to 15 degrees it will help me increase the surface area on the bottom or am I better to reduce the deadrise at the front 1/3 section of the bottom? I’m trying to achieve 200mm draft. Current estimates calculations about 350mm. Boat weight about 250kg and 100kg motor. Rear deadrise 4 degree changing to 8 towards the bow.? Thanks in advance
