40hp Yamaha on a Carolina Skiff JV15. Too much?
975 views 4 replies 3 participants last post by  JRyno10
#1 ·
Saw a jv15 with a 2016 40hp yamaha 4 strike on marketplace. Boat looks great but just wondering if the 40 is too big for this boat. I haven’t seen many of the jv15 and j16s with more than a 30
#2 ·
Yamaha 30 and 40hp are the same motor; differences are ECU and intake restrictor. So if you've seen them with Yamaha 30s you're ok. That motor weighs about 215 lbs.
For Suzukis, the 25/30hp are the same - 3 cylinder that weighs about 175. So if you've only seen them with Suzuki 30s, maybe a Yamaha 40 is too much.
#4 · (Edited)
I did the google. JV15 has a hull weight of 517 and a max gross weight of 870. That gives you a working capacity of 353 lbs. Take a 215 lbs motor and you're down to, ummm, 135 lbs. I agree with you that a 40 is technically too big for that hull. Now, if you are smart and trim it right and don't load everyone on the transom, I think it'll work fine.
EDIT: Actually I think that 870 gross weight has got to be passengers only, not the max weight people, motor, gear. So yes, I think it'll be fine. Also the press photos from CS show it with a Yamaha 40.
