I picked up a 2004 Honda 4 stroke 20 hp for my classic. Before I use I wanted to replace the oils.
For the lower unit is Quicksilver Gearlube ok or is the viscosity different from manufacture's recommendation.
Also I was planning on changing the engine oil with quicksilver 5w-30 platinum.
Any suggestions?
Do you have to fill from the bottom on the lower unit or can you fill from top and turn prop. I heard it both ways.
Any thing else I should change since I don't know the prior owner's maintenance schedule?
Thanks,
Any suggestions?
Thanks,
