1 - 10 of 10 Posts
Hey I am trying to find out what drive shaft to get, to replace the one in my 28L, so that I can make it into a standard, short shaft motor. I was told that the 28 only ever came as a long shaft, so it does not seem that I can simply order a 28 short shaft drive shaft, to replace it with. Any help advice would be greatly appreciated, Thanks.
so I have a 33 ski twin, from about 1966, do you think that might bolt up to the 28 powerhead?
I have herd that the 28 is a 30 powerhead with a 20 lower unit? or something like that. This makes matters confusing when figuring the splines on the shaft may be for 2 different motors top and bottom. IDK?
I thought the 9.9 and 15 were the same, and the 18 and 25 were the same. and the 30, 33 and 35 were all the same too?
Look at the parts diagrams on shop. Evinrude.com--parts for the model years in question to see if the drive shafts are compatible. I believe the 28 has an older design for the lower unit with no thu prop exhaust. That older design lower unit can be found on the 25's from a few years earlier if you want to compare. I assume you would have to deal with the water line and shift shaft too.
Thanks everyone for the replies, I did a lot of digging around and seems yhat the 28 only ever came as a long shaft, it has an older style bottom which was used on latter commercial engines, but the top end is based on a 30. So the shaft is ....IDK, I decided to build a jack plate, and raise my motor up a few inches. should work just fine. a buddy I work with can tig weld so were gonna fab up a custom bracet.
2020 Salt Boatworks FRS-14
Where are you located? I have a half dozen or so OMC's from 9.5-30 collecting dust here in Central Texas you can try.
Michael
1 - 10 of 10 Posts
