anyone ever experience this problem before? This is 2006 tiller model. Shifts from neutral to forward very smoothly but "stuck" when it comes to shifting from neutral to reverse.
Any suggestions? Thanks
Thanks guys, I appreciate the diagnosis....I did have the LU off a couple of months ago replacing the water pump but after reassembly it worked fine but obviously I must have done something wrong..Thanks again!
Look on the Side of the engine and try to shift it manually by hand, if it goes into gear it's in the linkage, cable, or tiller handle. If it still won't go into gear then it's in the lower unit.
