1 - 20 of 46 Posts
50 TOHATSU W/ APPROX 2 HOURS
2021 McCLAIN TRAILER
SIMRAD GPS
WET SOUNDS SOUNDBAR
BOAT IS LOADED
2021 Sabine Versatile aluminum poling skiff hull, rear dry storage hatch, 15 gallon
built-in fuel tank, under gunnel rod holders, 6 rod tubes, black rub rail
Basic Rigging - AGM 925 Cranking Battery, Battery on/off switch, Blue Sea
12 panel fuse bank, 750 Rule bilge pump w/ switch, Pop-up cleat on fore deck,
hull painted (1) color customer's choice. Tiller Edition w/ bull handle switch mounting
Standard poling platform w/ Seadek, Seadek cockpit floor and VMarine pushpole holders
12020 Tohatsu 50hp 4-stroke 15" Shaft - electric start, tilt/trim
12021 McClain HD Aluminum Trailer - torsion axle, 13" galvanized rims, led lights and SS Boatbuckle tie downs
SKIFF OPTIONS
1One color - Awlgrip Sea Shell Green F4143
1Tunnel hull
1Tubing bench seat - with two cup holders able to have a GPS mounted
1Atlas or Bob's Micro Hydraulic Jackplate - installed
1Large front casting platform with SS tie-down hardware
1Lenco Trim Tabs w/ single switch
1Powder coated Parts (black) - trim tabs, poling/casting platforms, nav lights,
pop-up cleat, steering wheel and latches
1USB Power plug mounted inside storage compartment
112V Power plug
1Fire Extinguisher - installed
1(2) LED under gunnel lights 90" long and switch - RGB; green, red, blue or white
1Vmarine Pushpole Platform Holder - installed
1Seadek front deck lid with Sabine logo
1Seadek full under gunnel w/ Sabine logos - one color )
1WetSounds soundbar mounted under front deck (soundbar, front deck extension and installation)
1GPS Install - Customer to provide GPS
1SIMRAD Go9 GPS
MOTOR OPTIONS
1Custom 3 blade propeller - for tunnel hull
1Tilt/trim switch - center bench seat
1Jackplate switch - center bench seat
1Tohatsu factory white
1Carbon Marine tiller extension
1Analog fuel gauge
TRAILER OPTIONS
1Trailer Spare Tire and Bolt-on Kit
$47,500
SEAN
512-777-NINE ZERO NINE ONE
1648 Aluminum Custom Joe Boat, 35 Evinrude
Assuming anyone is looking for that style of skiff, that is a lifetime rig hands down.
Sorry for the bad delivery of the question! I am curious if the seller is not happy with the performance for which he was expecting when building the vessel. Not happy with the lay out? Building boats is like building houses, there is always something you would change after the fact! I have been eyeing Sabine versatile’s for a couple of years now for south La fishing and hunting on the deltas but have not personally spoken to anyone with a Sabine because they’re not in our area as much as the Texas coast
1 - 20 of 46 Posts
