1 - 20 of 35 Posts
Just got back from ECC and got the new skiff all lined out.
- Boat hull and console are light blue (a tad darker than ice blue), cap is matterhorn white
- Center console with insulated jump seat
-Switches, ignition key, and USB port in glove box
- Awlgrip for interior
- Standard Aluminum Trailer
- Suzuki 60hp white
- Batteries, fuse block, and battery switch in hatch under seat
- Minn Kota Ulterra I Pilot, 80# with 54" shaft
- Three forward facing and one rear facing rod holders under each gunnel
- Black rub rail
- V marine push pole holders
- Simrad NSS9 Evo3 with Suzuki Connect Gateway for all engine data on the Simrad. Shoot thru hull transducer with depth and temp
- Atlas Micro Jacker
- 6' Power Pole white port mounted
- Casting platform permanent mounted to front hatch
- Casting and Poling platform have snow camo sea dek
- Gunnel cup holders on each side
- Grab rails on each side of console
- Lean bars for both platforms. Curved for casting platform and straight t for poling platform
- Push Pole holder on starboard side
-Upgrade to PC1500 batteries
- Onboard three bank charger
- Raycor fuel/water separator
- No livewell setup.
Pics to follow in a couple of weeks once we get in to the mold.
I'm going with the Simrad NSS9 Evo3 as well. Which transducer did you get?
In Hull (shoot thru hull) for depth and temp. Its not as accurate as an external temp measurement but its plenty good for what I need and it eliminates any external wiring or penetrations. Had the same type setup on my Vantage and it works great.
PS - PM sent
1 - 20 of 35 Posts
