1 - 3 of 3 Posts
2018 Custom Center Console Flats Skiff
This skiff is really set up like a bigger center console, so there is plenty of room and a much more comfortable driving position. The interior has a lot of room for this size boat and has a tri hull keel that cuts through a moderate chop, but still floats/runs in shallow water. The boat is in perfect condition. Everything is super clean and works well. I have to sell because we have another baby due in February and I know the boat will sit without being used much anymore. Everything was professionally rigged, done right and clean. You will see where every hole has 5200 sealer and stainless hardware used so you will not have to worry about any water damage. If you see this boat in person, you will appreciate it much more!
- 16' Riviera Hull (been made for over 40 years. Flotation in the gunnel sides instead of the bottom for a much stronger boat and won't flip if flooded)
-Yamaha 40HP Four Stroke Motor (very fuel efficient). 30 MPH with 1-2 people. 25-28 MPH with 2+ people.
- New spare prop and hub
-Racor fuel filter and water separator
-Lowrance Depth Finder
-Stereo with 2 Speakers
-Superstick Shallow Water Anchor
-Carver White Vinyl Bimini Top w/boot cover (Made in USA, not a cheap $200 top)
-Leaning Post and Rocket Launcher (makes this skiff very unique. Perfect space underneath for Yeti 20 Cooler)
-Kodiak removable and plumbed livewell that attaches to 750GPH livewell pump. Can be put on for fishing or taken off for more room while crusing. Will hold several dozen baits.
-Interstate battery with battery switch.
-13 gallon aluminum tank in the console, not under the deck.
-1000 GPH Auto Bilge Pump
-Front Casting Platform with storage underneath. Connectors to strap down Yeti 20 Cooler to double as an elevated casting platform for sight fishing.
-Performance Galvanized Trailer (Spare tire and holder on trailer, Complete Spare Hub Set with Bearings already installed, Lock nuts on wheels, Trailer wheel security boot, coupler lock set)
-Rod holders on side of console
-Seat cushion on front console seat.
Call Matt 954-288-8113
$8,800
I'm probably missing stuff, but I tried to include everything. Call or text me with any questions.
1 - 3 of 3 Posts
