2017 Hell’s Bay Professional in immaculate condition with many upgrades. If you know anything about Hell’s Bay Boatworks you’d know the passion, quality, and attention to detail Chris and his team dedicate to building these skiffs is incredible. They’re light as a feather, poles like a dream, and run super skinny. Extremely dry and cuts through chop very well.
Of course all scheduled maintenance was done, engine oil, lower unit oil, water pump, impeller, gaskets and seals, prop shaft and all zerks greased.
Always ran non-ethanol fuel in her
Full fuel, tournament load and 2 guys:
Cruises at 5100 rpm at 29mph getting 7.1 mpg
Top speed 6200 rpms at 34mph getting 5.7 mpg
I love this boat and always will, she’s outperformed herself in every way possible, and made for some great times on the water, but it’s time to get something a little bigger to do some different type of fishing.
Build sheet is available upon request
$48,500
1 owner
Boat is located in Orlando
Please no brokers or dealers
If you have any questions call or text
407-492- zero seven eight eight
Thanks, Reese
- Guide green hull with cream deck
- Yamaha F70 with 169 hours
- 2017 Ram-Lin dry launch trailer with spare and Boat Buckle rear tie downs
- 9” Raymarine Axiom with DownVision/SideVision/RealVision 3D and NMEA 2K network that reads all motor data
- Minn Kota Ulterra 80lb i-Pilot with auto stow/deploy and power trim (it’s the 2nd gen where they fixed all the problems, works flawlessly) with 2 dedicated Optima batteries
- Power Pole 6ft Signature series
- 22' Stiffy push pole
- Fold down backrest/step with cushion
- HB custom fiberglass front casting platform with matching gel coat
- Matching cream SeaDek on poling and casting platform with HB logo
- Custom fiberglass molded Yeti drink holder built into poling platform deck
- Insulated cooler like a Yeti under front console seat (actually will keep solid ice all day even in the direct sunlight)
- Powermania Turbo M320V2 3 bank charger
- Upgraded tilt steering
- Hook tying eyelet under binnacle controls
- White LED lighting in all compartments
- Blue LED under gunnel lighting
- Mr. Bubbles livewell bubbler
- 2 livewell pumps
- Had HB install a backup bilge pump with its own output line (2 total)
- Custom Sunbrella covers for console and Power Pole
$48,500
1 owner
Thanks, Reese
