2016 Ankona Shadowcast 16
Mini center console grab bar
8 gallon Aluminum gas tank
Under gunnel rod holders
Poling platform with stake out bracket
Garmin echo map dv GPS / transducer
Rule 500GPH bilge pump
Carbon marine tiller extension
Tibor push pole caddy
Stiffy push pole holders
Hella anchor light
Navigation lights on console
Electrical package from factory
Battery switch
Wired for 12v Minn Kota trolling motor never used
Boat cover included
NO push pole
2016 Suzuki DF20hp electrical start with pull cord. 100 hours estimated. Non ethanol use only. Cranking battery in console. Maintained annually
2016 continental aluminum trailer torsion axle, Good tires, new hubs last year
Got this boat brand new from the factory August 2016. Haven’t had much time to use only reason for selling hardly used the last year or so. One of the rims is dirty from a hub blowout it was replaced. Skiff is very lightly used always stored under cover.
18-20mph wot with around 450lbs of men + gear
Located in Stuart, Fl
Asking 12k
Please call Cullen @ 772-233-0156 for more info & questions thank you!
Hella anchor light
Battery switch
Boat cover included
NO push pole
Asking 12k
