1 - 3 of 3 Posts
Hey guys,
Need some mechanical assistance...
Motor is a 2016 merc 30hp efi tiller.
So when I start motor everything is fine. When I shift back into neutral from F or R, the rpms stay high...once I remove the cowling and manually push the throttle linkage back to its position the rpms will come back down to where its soppose to be. Once I do this, it will not give me this issue again. I can shift 100 times and/ or fish all day without a problem..when the boat sits over night, and I start it for the first time again, the issue is there until I correct it manually. Could the throttle linkage and/or moving parts need a little spray of wd40 or something? Although I'm temporarily correcting it by manually pushing it back, I would like a permanent fix.
Thx for the help in advance and let me know if I'm missing some more detailed info.
98’ Whipray
Cable might be stretched. Or try adjusting the cable so there’s a bit of tension on the linkage. That’s where I’d start. If there’s no more adjustment left I’d say the cable needs to be replaced.
ill take a closer look at that, that you sir!
1 - 3 of 3 Posts
