1 - 16 of 16 Posts
Price Drop: $19K OBO.
I've decided to put my Shadowcast 18 up for sale. I took delivery in October 2016 and rigged the boat over the next month. This has honestly been the best boat I've owned. I built it for fishing/camping the Glades and the Big Bend. The combination of shallow draft, shallow running (with the tunnel), range (100+ miles per tank) and length make it perfect for my style of fishing. It does surprisingly well in a chop for a skinny poling skiff. Performance is 25-26 MPH WOT with a cruise at 22-23 MPH getting ~10 MPG. The boat is a blast to drive either standing in the cockpit or on the back deck.
- SC 18 w/30hp Tohatsu tiller four-stroke, electric start & power trim
- Ice Blue topsides and Matterhorn White hull.
- 250 hrs on engine, all scheduled maintenance performed
- 12 gallon built-in aluminum fuel tank
- Float-on aluminum trailer, torsion axle, swing tongue, spare-tire & hub assembly, new LED tail lights, radial tires (replaced in March 2019).
- Enclosed front and rear deck hatches with additional bulkhead coring glassed in for mounting accessories.
- Jump seat tiller console with livewell
- Motorguide Xi5 55lb Pinpoint GPS trolling motor on quick release bracket
- Group 31 Duracell AGM battery in bow with breaker.
- Two-bank Noko sealed on-board charger (10A/bank)
- Simrad GO7XSE with Totalscan transducer
- NEMA 2000 network with Simrad gateway to both engine and Motorguide trolling motor.
- Charge-on-the-run system with Blueseas ACR. I can fish for days in the Glades without having to worry about battery power.
- Perko disconnect switch
- 750 GPH bilge pump
- 55 AH battery in console for engine/accessories.
- Custom acrylic Bocatech switch panel (8 switches), dual USB ports (w/breaker), 12V port (w/breaker), additional trim/tilt switch, ACR ground disconnect switch. The Bocatech switches are LED with resettable breakers. The panel is blue LED backlit.
- Moonlighter 22' carbon push pole
- Marinemat on poling platform
- Powertech 4-blade stainless prop
- V-marine push pole caddy on platform
- Hella marine stern light and console-mounted LED nav lights
- Blue LEDs under gunnels and white LEDs in all hatches/console.
- Removable poling platform lean bar
- Triple Taco Marine rod holders on both sides of console.
- Birdsall Marine rod holders on platform (2)
- Stake-out pole system
- Anytide extension handle
The boat has always been stored indoors and is in extremely good condition. Flushed and washed after every use. I'm asking $19k OBO. The boat is located in Merritt Island and I'll be happy to water test for anyone with serious interest. Call or text 904-708-0689 or email at [email protected].
Water transportation Vehicle Boat Watercraft Skiff
Water transportation Boat Vehicle Water Boating
Vehicle Water transportation Boat Speedboat Boating
Technology Electronic device Auto part Electronics Measuring instrument
Water transportation Vehicle Boat Skiff Boating
Transformer Technology Automotive battery Machine Gas
Vehicle Car
Electronics Technology Electronic device Computer case Audio equipment
Vehicle Bass boat Water transportation Speedboat Boat
Bicycle part Bicycle handlebar Bicycle saddle Vehicle Bicycle accessory
Nice skiff - i have one with a side console. Question, how did you get your simrad hooked up to get motor telemetry? I have same motor and same simrad and would like to do the same.
Thanks
Discussion Starter · #14 ·
No crack. Just how Ankona lays down their caulk.
Motor telemetry requires N2K backbone and two harnesses. One is the 3NV761330 interface cable and the other is the 9999HN0869 engine to N2K backbone cable. Will run you about $150 total on boats.net for the Tohatsu harnesses if you already have the backbone.
BTW, boat is sold to a great new owner in Crystal River.
Discussion Starter · #16 ·
I would just buy the N2K starter kit (available everywhere). That will give you the hardware to get started (terminators, T's, etc.). After you have the starter kit, it's easy to build on the network with connections to your MFD, engine, trolling motor, etc.
1 - 16 of 16 Posts
