**PRICE REDUCED**
$19,300
Need it gone to start my new build
Contact me on MicroSkiff or e-mail at [email protected]
For sale, 2015 (delivered in mid-December) Beavertail Micro 16 Skiff with 2015 30-hp Evinrude E-TEC tiller outboard and Peterson aluminum trailer. Located in Naples. Clear title in hand.
This is an impressive 1- or 2-man poling skiff, with a draft less than 5 inches loaded and speeds in the mid-20s. It will literally float and pole in water only kayaks can access. Run all day on less than 3 gallons of gas. Easy to load, trailer and store. I have been in three-foot seas and have stayed bone dry while running at 5,000 rpm.
Specifications:
LOA: 16' 8"
Beam: 60"
Draft: <5"
The Micro has a large front storage compartment in the bow casting deck that also houses the removable 8-gallon powder-coated fuel tank. Only non-ethanol gas has ever been used, along with Evinrude XD100 oil. A custom aluminum helm pod/grab bar includes mil-spec system switches, a fuel gauge and tachometer, Ritchie compass, Lenco trim tab controls, vertical rod holder, Garmin 44DV Down Vu GPS/chartplotter with coastal charts. The forward frame holds a 35-quart Engel roto-molded cooler with custom light gray seat cushion. Sea Dek pads protect the reels and under-gunwale rod racks will hold six combos up to 10-feet long. The rear deck includes a 10-gallon live well with acrylic lid, light gray seat cushion and the aft storage compartment/systems locker. There is also access to the fuse/wiring panel, automatic bilge pump, Odyssey AGM battery and fuel/water separator filter. A sturdy poling platform is equipped with a Sea Dek pad with BT logo, plus a welded rod holder and receiver for a manual anchor pin. A Tibor push pole holder is also included, along with V-Marine black spool push pole holders on the starboard gunwales. The Micro is equipped with premium stainless steel hardware and waterproof electrical connections and all composite materials. The weight is 400 pounds. The hull sides are finished in Awlgrip Haze Gray Color, while the top cap is Awlgrip Chevy White Color (very light gray to cut down on glare). A custom bow casting platform with Sea Dek, Pfender Pro quick release mount and turnbuckle is included. The boat is pre-wired for a bow trolling motor with aft battery tray, circuit breaker and bow quick release puck and connector plug. The GPS comes with the boat along with an extra set of all wires that would need to be ran for the gps and any extra transducer. An extra bow quick release puck also included.
Engine: 20-inch shaft 2015 Evinrude 30-hp E-TEC direct-injection two-stroke outboard. Under factory warranty for another five years! Rigged with a PowerTech three-blade stainless steel prop. Power tilt and trim. Instant electric start with manual back-up. Comes with a Carbon Marine tiller extension with tilt and trim control. Also rigged with black powder-coated Bob's cavitation plate (Whale tail) for better hole shots and top-end performance. 155hrs
Trailer: Peterson aluminum trailer with radial tires, galvanized wheels and many upgrades, including spare tire, wheel and hub assembly, Fulton F2 winch, rubber mud flaps, Stolz poly keel roller with stainless pin, Glide Slicks on both bunks, with side bunks and PVC guide posts for easy loading and roller on the back for dry launching.
Excellent condition. Professionally maintained, washed with soap and water and engine flushed after every use. GARAGE KEPT ITS WHOLE LIFE. The whole boat is waxed every month, including hull, deck, cockpit, all powder coat, engine, and inside the hatches. All metals including prop, trim tabs, and all stainless is also polished every month.
$19,300
Specifications:
LOA: 16' 8"
Beam: 60"
Draft: <5"
