*Updated with new pricing and detailed equipment list
2014 Vantage VHP
Flats tower, black out package on boat and trailer
Suzuki 140 (226 hours), 4 blade custom prop, 3 blade speed/cruise prop
Atlas jack plate
36 gallon gas tank
Offset folding bow cleat
East Cape stake out through hull fitting for using stake out stick from bow
Oversize front casting platform with lean bar. Can be positioned from the front or rear of platform
Huge front deck hatch with hatch in a hatch
Two deck fittings for casting platform, one on bow and one on front deck hatch
VMarine removable black anodized pole holders with bungee keepers
Front bulkhead rod holders
Under gunnel rod storage, 3 rods each side, under gunnel SeaDek
Removable jump seat in front of flats tower
Integrated cooler in console with 2" insulation and drain to bilge
Ulterra 80lb thrust trolling motor
2 Odyssey PC1200's, Power Mania onboard charger in console riser box. 1 Odyssey PC1200 for starting, house battery in riser box
Edson black ops wheel with speed knob, brand new
Lowrance HDS 7 gen 2 touch with side scan, down scan and regular sonar. Navionics Platinum+ nav chip with Hot Spot maps waypoints. Current firmware updated on Lowrance and Navionics chip updated 02/2020. Standard transducer epoxied in bilge will read depth up to 40mph in 2' of water. Total scan transducer with side scan and down scan on transom.
Sonic Hub with 4 Rockford Fosgate speakers
Leaning post has 2 welded rod holders on back
Lenco electric trim tabs with new console switch
8' Power Pole Blade, two key fob remotes, new console remote
36 gallon livewell/release well with aeration control valve
Port side aft dry hatch with drain to bilge, starboard side aft dry hatch has fuses/Power pole motor/battery switch/jackplate relays
Two step poling platform with drink holder, VMarine push pole caddy, welded tubes for lean bar
All hatches have key locks
Factory guaranteed transferable composites warranty
This boat has been kept in storage or in a covered slip at my house. Has full boat cover that fits with front platform in place. Has individual console, leaning post, poling platform and Power Pole covers. Runs 40-43mph WOT, average cruise is 28-30mph @ 6.5mpg, floats in 9-10" depending on load.
Located in Galveston, Texas
$38,000
Bittersweet putting her up for sale but I’ve ordered a new skiff. If you are looking for a do all boat, skinny or deep, beachfront or marsh, family cruise to the sandbar or sight casting the flats this boat will get you there and back in comfort and style.
