1 - 10 of 10 Posts
cold compression test done on a 2013 yamaha 4 stroke 70hp
numbers are between 95- 105psi. does this seem right? around 150 hours. seems real low for such a new motor.
I think compression should be checked on a warm engine. No idea what the compression should be.
Make sure intake flap is wide open when testing compression.
With the butterfly closed it restricts airflow, giving lower readings.
Cert. Yamaha technician
Its fine
Go find two other guages and see what they say.
Guarante you they wil all be different. Possibly higher or lower
Yamaha no longer recommends compression test on 4-stroke engines, A leak down test should be performed.
Agreed. Its a little more work but if you know what your doing it can tell you ANYTHING you need to know
Discussion Starter · #9 ·
its for a boat that im looking at picking up. boats not in my area and the owner took it to a dealer to for a check up. every thing else seems good. i may run my own when i see the boat in person.
1 - 10 of 10 Posts
