I already noe that...
Hi everyone if you could help me out on what you think I should to fix this solution that would awesome. I know it may be the impeller, but I am wondering if there could be anything else I should try before going any further. If you could also maybe send me the diagram for the lower unit of the motor that would be highly appreciated.
Can of compressed air out of the electronics dept is good for spraying into the pee hole while running the motor on the muffs. I there is something clogging it up that usually gets it.
dont mean to thread high jack, but im experiencing the same thing with a 9.9. The thermostat was rotted out, so i removed that still the motor does not pee, however if you put your hand in front of the pissing line you feel air coming out. Would water pump change fix this (fingers crossed)
