SOLD/EXPIRED 2012 Hells Bay Waterman 18 For Sale
Discussion in 'Sold/Expired Classifieds' started by DestinyUnbound, May 3, 2015.
  1. DestinyUnbound
    DestinyUnbound I Love microskiff.com!
    2
    2012 Hells Bay Boat Works Inc Waterman 18,-60hp Yamaha 4 stroke (still has over two years of warranty left! Warranty expires July 2017) 359 hours as of 4/29/15 -Power Tech 4 blade stainless prop-Atlas Micro jack plate, blinker switch on helm -SeaStar hydraulic steering. -12 volt Minn Kota CoPilot mounted on stern port side -Optima cranking and trolling motor gel batteries -23 gallon baffled aluminum Ceram-Kote fuel tank -Lenco trim tabs -Edson "Power Wheels" steering wheel -5 rod tubes on port side (1 pointing aft), 3 rod tubes on starboard side. -Renzetti machined clear anodized aluminum push pole holders -Clear anodized poling platform w/ reinforcement under the deck for a Pro Trim Cage (holes drilled),Cool gray Sea Deck w/ Hell's Bay logo on deck -Custom clear anodized casting platform, two turnbuckle tie down system, Cool Gray SeaDek on top, holes drilled and tapped for Protrim line tamer and cage -Schaefer stainless steel fast entry cam cleat on bow -1100 GPH Rule Bilge Pump (4 months old) -Livewell ready for plumbing -light gray seat cushions with dark gray piping (bolt on) -Livorsi LED Shark Eye Nav lights -Sealed LED anchor light (aft) -Ram-Lin aluminum trailer (new axle, hubs, and bearings bought in February! Not a speck of rust!) -Kingston Gray hull (shines like a mirror!) Whisper Gray non-skid. Beautiful two tone color scheme. -Awlgrip sprayed hatches, No stains! Easy to clean! -"Piano" hinges on all hatch lids (gives the deck a very clean, uncluttered look). -Gray carpet under gunwales -LED cockpit lights, white -LED hatch lights, white -Large Moonlight hatch springs -Stainless steel hand rail on top of port side gunwale -Retractable cleats placed on both gunwales at midships -Side Console with Extension in front for GPS and Stainless cup holder -Garmin 441s GPS and Sounder -Ritchie compass on console -Rigging loop mounted on console -Lenco trim tab switches placed directly in front of throttle/binnacle -Phenolic reinforcements glassed in at all point load and stress areas on deck (Casting platform turnbuckle mounts, trolling motor, poling platform, push pole holders) Phenolic also used to reinforce transom, D rings on the stern, and winch u-bolt on bow. Incredibly strong boat for its weight! Incredibly clean and well maintained. 21 foot Stiffy Graphite "Guide" model push pole, Tibor push pole caddy, and Yeti Tundra 45 cooler w/ Yeti seat cushion sold separately. For those of you that live in south Florida, I can deliver the boat to Titusville, FL so you won't have to drive all the way to the panhandle. Located in Santa Rosa Beach, FL $40000, 8502253813
    http://www.boattrader.com/listing/2012-Hells-Bay-Boat-Works-Inc-Waterman-18-653726
