1 - 6 of 6 Posts
2011 Yellowfin 17 Skiff
2011 Mercury 60HP Bigfoot 4-Stroke
2011 Loadmaster Trailer
2015 Minn Kota iPilot Trolling Motor
Located in Hilton Head, SC
I acquired this skiff a year ago and made a lot of updates and improvements. Absolutely the finest poling skiff I’ve owned and an unbelievably good ride for a 17 footer. While I don't want to sell the 17, I've been running a larger boat that better suits my needs and it’s hard to justify having both right now.
Priced to sell at $29,900
Includes:
Boat/Motor/Trailer
2015 iPilot trolling Motor with AGM batteries and charger
Lowrance HDS10 GPS/Sonar with Structure Scan
Stiffy Extreme Graphite Push Pole
Additional Features:
— Mercury Smart Gauge
— 35 Gallon Live Well
— 2x Welded on Rod Holders
— 6x Console Rod holders
— 2x Taco Clamp On Rod Holders
— Lots of under gunnel rod holders
— Lowrance Structure Scan
— Lowrance Sirius XM Weather Radar Antenna
— 8' Power Pole with 2 remotes
— Center Console Custom Grab Bar
— SeaDek under gunnel for rod protection
— BayStar Hydraulic Steering
— Mercury stainless steel prop
— Atlas Hydraulic Jack Plate
— Lenco Trim Tabs
— LED navlights
— Blue LED courtesy lighting
— Removable Bow Casting Platform with Sea Dek
Recent updates and improvements:
2014 (previous owner) — New BayStar Hydraulic Steering
2014 (previous owner) — New Throttle and Shift cables
2014 (previous owner) — New Trailer Hubs
2015 (previous owner) — New Trailer Tires
Fall 2015 — New Gemlux Hinges. Old ones didn’t shine. New ones do. I’m picky about the little details.
Fall 2015 — White Interlux bottom paint with barrier coat. Yes, you can’t even tell it’s there and it does not impact performance. It’s a slick white paint and is the same I run on my offshore boat.
Fall 2015 — New keyswitch. Old one was a little flaky, no issues now.
Fall 2015 — Replaced Push Pole clip bungees.
Spring 2016 — 2x Taco clamp on rod holders added to increase total rod holders on the poling platform to 4 (the other two are factory welded).
Spring 2016 — Added Wet Sounds Stealth Ultra 10” amplified bluetooth speaker bar. This is a full powered audio system, and it mounts perfectly under the poling platform.
Spring 2016 — Added trolling motor and new AGM batteries, charger
Spring 2016 — New Racor SS bracket external fuel filter / water separator
Fall 2016 — New Lenco Trim Tab control box
___________________________________
Includes:
Boat/Motor/Trailer
— Lenco Trim Tabs
— LED navlights
Text more pictures to 2394043117
I am very interested in your boat. Would like to discuss live w you. Scott Barker 864-380-9161. Please let me know when we can talk. Thanks Scott
Includes:
Boat/Motor/Trailer
— Lenco Trim Tabs
— LED navlights
Txt more pics to 864-380-9161
1 - 6 of 6 Posts
