2011 Gheenoe LT25 project. Was a raptor set up, someone tried to convert it to tiller and clean cut the raptor portion off. Can easily be welded back on. Boat needs some TLC. All aluminum trailer is in decent shape, could maybe use tires soon. A limb fell on it and messed up the gunnel rubber and put a tiny crack in it. Has Lenco trim tabs that work as far as I know. Boat is in decent shape and had sea deck throughout that someone pulled out and there’s still a tiny bit of glue in it. Has the front nose cap for an ipilot with quick disconnect. This boat could be flipped by someone who knows what they are doing. I just don’t have the time to mess with it with a new born. Atlas micro jacker needs work. 4300 OBO located in Jacksonville FL
Tire Wheel Bicycle Bicycle tire Automotive tire
Automotive tire Asphalt Road surface Gas Motor vehicle
Land vehicle Tire Wheel Car Vehicle
Plant Wood Window Road surface Rectangle
Wheel Plant Tire Motor vehicle Automotive tire
Window Building Plant Road surface Vehicle
Tire Wheel Boat trailer Vehicle Boat
Plant Asphalt Motor vehicle Gas Grass
Plant Asphalt Motor vehicle Road surface Wood
Bicycle tire Bicycle handlebar Automotive tire Bicycle frame Bicycle fork
