SOLD/EXPIRED 2011 Ankona SUV17
Discussion in 'Sold/Expired Classifieds' started by bamboobill, Sep 24, 2012.
  1. bamboobill
    bamboobill I Love microskiff.com!
    51
    Despite the best intentions, this boat is just not getting used. That said, it doesn't make sense to leave her sitting in the side yard, so I'm going to sell her on to someone who will hopefully use her more.  She's been in the water 6 times, with less than 15 hours on the motor.  Boat stored covered.
    I listed this boat back in June, but pulled it off the market  at my wife's request right when it looked like I had a buyer.  She said she didn't want to let it go and that we'd (she'd) make more time to use it.  Since then it hasn't even been hooked up to the truck, so here it is again and I will sell it this time around.
    Hull
    - 2011 Ankona SUV17
    - Hull color Key Lime green.
    - Interior color Matterhorn White with a tint of Key Lime, Key Lime and Gray webbing.
    - Full deck cap, glassed in molded front bulkhead with flush hatch, lifting/locking rear deck with SS gas props over glassed in locker box.
    - Tiller console with grab bar, flush hatch/door to access storage under.
    Motor/Power
    - 2011 Nissan TLDI 40hp tiller, electric start and TNT, 15 hours.  Under warranty
    (3+1, 13 months remaining Major Components, 25 month on TLDI Technology).
    - 10 micron fuel filter with water separator.
    - DEKA marine group 24 battery, 1000 CCA.
    - Strongarm aluminum tiller extension.
    - Top speed recorded, 32 mph, dead flat water, stock prop, 2 largish adults and 2 toddlers plus gear, measured via GPS.
    Trailer
    - 2011 Continental C7-1500 Galvanized.
    - Jack stand.
    - PVC rotating guide-ons.
    - Spare tire on bracket, mounted on tongue.
    - Various hitch locks.
    Factory Options
    - 12 gallon aluminum fuel cell under front deck.
    - Crustacean well mounted in front deck, right rear.
    - Pop up bow cleat.
    - Push pole holders.
    - Under gunnel rod racks, left & right, with carpet behind.
    - Running lights, mounted on console sides.
    - Anchor light, mounted on motor cowling.
    - 1100 GPH auto bilge pump.
    - Switch panel (rocker), mounted on console, anchor light, running lights, bilge pump.
    - TNT control wired to console (also on tiller).
    - Analog tachometer.
    Accessories Included
    - Humminbird 363 GPS/Fish Finder (installed by Ankona).
    - Fully removable 5 gallon bait well setup, with transom mounted 500 gph pump.  Works great, flows with pump off while running, ball valve to regulate flow, drains over side.  Pump is removeable via a bracket.  Pump, hose, and tank can be easily removed, leaving just the transon bracket and a clip on top of transom that holds the hose.
    - Shumacher automatic 2 amp maitenance charger (keeps battery topped off and ready to go).
    - USCG required equipment - flares, noise makers, etc., PFD's (2), throwable, fire extinguisher.
    - Dock Lines (2)
    - Moller 3 gallon auxillary tank with hose and Nissan connectors.
    - Taylor boat cover and motor cover, in good condition.
    - 1 gallon of Nissan approved engine oil.
    - A handful of odds and ends.
    Note:  The Yeti cooler pictured with the boat is NOT included in the sale.
    Price - $9,250 firm.  Title in hand.  Tampa Bay area.  EMAIL if interested:  wcbenham (at) yahoo [dot] com.  I don't check PM very often, so please use email to contact me about the boat.
  2. bamboobill
    51
