2010 Evinrude E-TEC 60hp prop
1840 1
Greetings, I am currently running a 13 1/2 15"pitch aluminum BRP prop on my 16ft flats boat. This is a OEM 3 blade model. I get about 5750 RPM at WOT. The boat is stern heavy so I was thinking about trying the Rogue 4 blade either 13 1/4 or 13 1/2 prop in the same pitch 15. The boat does not have trim tabs so I was curious if this prop would help. I was also wondering if the change from the 3 blade aluminum to the SS 4 blade prop would affect my RPM range any? Thanks guys I look forward to hearing your input.
BTW the prop I was looking at buying is the Rogue BRP PART # 763965
