SOLD/EXPIRED 2010 Ankona Copperhead Technical Poling Skiff
Discussion in 'Sold/Expired Classifieds' started by greenwater, Mar 17, 2015.
  1. greenwater
    greenwater Texas Copperhead Owner #2
    29
    - 2010 Ankona Copperhead (1st generation)
    - 16' x 60"
    - Desert Sand hull, custom Fighting Lady Yellow deck/cap
    - 2010 30hp Nissan tiller steer outboard w/ power tilt
    - 42" Strongarm tiller aluminum extension - black powder coat
    - Vance JPL4400 4"setback/4"vertical manual jack plate
    - Stainless 10x11 Solas prop
    - Custom aluminum poling platform
    - 21' MHX push pole (weighs 4 lbs)
    - 7' Stick-It anchor pin with "The Brake" @ transom
    - (3) Rear Tempress hatches (2 with storage, 1 battery access)
    - Fiberglass rear cargo locker
    - Fiberglass Front hatch
    - 12 gallon mounted aluminum fuel cell (150 mile range)
    - Bennett self-leveling trim tabs
    - 45qt Yeti with hold down straps for front deck/casting platform
    - 75qt Yeti with Yeti cushion
    - Under gunnel rod holders - each side
    - Front red/green combo and fold down white overhead lights
    - Fold-flat front cleat
    - Twin rear cleats for drift socks/anchor
    - 2010 Float-On aluminum trailer
    Gear included:
    - (2) 30" drift socks with rigging
    - (1) Type 4 PFD
    - (3) personal PFD's
    - Marine grade fire extinguisher
    - Claw anchor w/ chain and 50' anchor line
    - (2) floating dock lines
    - Flares/light/whistle
    - Spare aluminum prop and hardware
    All new fluids, filters, fuel separator, water pump, and thermostat as of today.
    It's ready to fish today.
    Runs in 12" at 28mph or so, poles in 5".
    SERIOUS BUYERS ONLY, PLEASE.
    $10,500 takes it all. Will not separate.
    Can be seen at my residence in Flour Bluff. No, I will not haul it around to show it to anyone. If you want your mechanic to check it, you pay all fees.
    Can be wet tested in the evenings and on weekends (weather permitting); call for availability as I travel a lot for business.
    361-877-4313
    Please don't PM me; I'm rarely on this site. My contact info above is best.
    High resolution pics found here...
    http://2coolfishing.com/ttmbforum/showthread.php?t=1391762
  2. Snookdaddy
    Snookdaddy Well-Known Member
    What happened to the tabs on the back? More importantly, who did the repair?
