SOLD/EXPIRED 2009 Loaded LT 25 / CC / 30 HP Tohatsu / Minn Kota Riptide $13900
Discussion in 'Sold/Expired Classifieds' started by think7, Jul 24, 2012.
  1. think7
    think7 I Love microskiff.com!
    4
    • 2009 LT 25, Key Lime green with matching Key Lime green Linex to water line
    • Center console with raised front and rear decks, shark eye bow lights, stern light (new 7/12), bilge pump, bow mount nose cap (refinished 6/2012)
    • A new 2012 LT 25 as built is now $9533+
    • 2009 30HP Tohatsu MFS30BEPTS - 158.2 hrs as of 7/5/12 , SS 4 blade prop, 2 spare aluminum props (spares both cupped), with tach and water pressure gauge
    • 2012 version of this motor retails @ $5624.00 + $235 for the tach
    • Serviced on 7/5/12 at Tohatsu authorized dealer, new water pump impeller, spark plugs engine oil & filter, Racor filter, lower unit oil, greased, ZERO hours since service
    • Humminbird 798 CI SI NVB Side Imaging GPS (just replaced by Johnson Outdoors 6/12), new bracket (6/12)
    • Aluminum / SS Continental trailer (upgrade)
    • 6 gallon tank + 3 gallon Tohatsu spare tank
    • Racor water separator
    • 2 batteries – 2009 Optima Blue Marine deep cycle (155 AH) for engine and Minn Kota,  2010 – Powersonic 18 AH gel battery for Humminbird
    • 2009 Dual Pro RS2 12 amp, 2 bank battery charger
    • New front pedestal bushing & new rear pedestal base replaced – 7/12
    • 2 Temptress pro pedestal Butt seats (white) – upholstery refastened with stainless staples (7/12) – front seat differs from jpg below
    • Hold My Pole push / anchor pole bracket with 14’ “Pole Cat” pole
    • Light gray Sea Deck in cockpit and both raised decks - also in bottom and sides of center console storage
    • Boat has just been back to Unlimited Glassworks for gelcoat touchups and looks as close as possible to new for a 3 year old boat
    • 2 x Scotty adjustable angle rod holders with flush mount deck receivers
    • 3 x SS pop up cleats
    • PVC rod holders + custom rod holder extension (PVC, removable with hitch pin) – holds a total of 8 rods on port side of console
    • Insulated cooler / fish box + extra insulation added in lid
    • 2 x (YES 2) Minn Kota RipTide 55lb iControl, iPilot, 12v motors with extra remotes, spare props, 60 amp breaker
    • Custom made Starboard easy release mount for electric motor (not the Minn Kota quick release) – we carry the spare in the truck – if you need to – the motors can be swapped out in 15 minutes (wired with Posi-lock connectors and mounted on the Starboard mount with 7/16” SS fasteners)
    • Center Console (2) and back hatch/driver’s seat (1) factory cushions
    • Sea Sucker mounted holder for pliers etc.
    • Over $21K invested, all invoices available.
      If you want a completely decked out, pristine, well maintained  LT 25 at a huge discount – this is it.
      Jeff – 352-322-0990 (cell phone no VM, home 352-489-4998) or email think7@bellsouth.net
      We’re in Dunnellon, FL about 100 miles from either Orlando or Tampa.
    • Images are from 2009 – new photos (still putting hardware back on after getting boat back from Unlimited Glassworks) available upon request
