SOLD/EXPIRED 2009 Beavertail BTX w/ 2009 60 E-TEC (Reduced to 18K) Tallahassee, FL.
Discussion in 'Sold/Expired Classifieds' started by cdaffin, Apr 12, 2012.
  1. cdaffin
    cdaffin I Love microskiff.com!
    127
    Contact me via email, cdaffin@gmail.com
    Just dropped the price, I need to move this thing. I need a mod to trash the other post, I can't edit nor delete it.
    Need to move into a bigger, more family friendly boat. I wish I could keep this thing, it's a fantastic poling skiff that will be missed.
    The boat floats in under 6" fully loaded, I've never actually measured it because there is no need, it will pole where a boat has no business. It handles awesome, and performance is typical of a flat bottomed poling skiff, tops out at 30 - 35 depending on load and prop. Handles a true 2ft chop great with the tabs and is as dry as you can possibly get in this type of boat.
    The hull has 2 years left of structural warranty that will be will be honored by Beavertail Skiffs LLC, original manufacturer of this Beavertail BTX hull. I can provide all contacts for this.
    Engine was just serviced and the trailer wheels, hubs, leaf springs and lights were replaced.
    Boat on trailer is 24ft long, 7ft wide, 6ft tall at longest, widest and tallest points. Height is with the leaning bar off.
    Options I've added:
    20' Stiffy hybrid push pole. (not pictured, it's new)
    Front casting platform.
    Minn Kota Riptide SE 55lb (This is practically brand new, purchased and installed 12/11)
    Brand new Interstate group 29 battery in the front hatch.
    Onboard Minn Kota 6a charger.
    Lecrotab trim tabs.
    Bob's 6" jackplate
    3 blade and 4 blade SS props (Evinrude brand)
    Fabricated bench seat w/ backrest and rod holders.
    Tibor push pole holder on poling platform.
    Leaning bar on poling platform.
    Extra tire / wheel on trailer.
    Specs and standard features from the manufacturer:
    Specs:[ch8232]
    LOA: 17' 10"
    [ch8232]Max Top Deck Beam: 72"[ch8232]
    At waterline Beam: 57"[ch8232]
    Deadrise at Transom: 4 degree
    [ch8232]Draft: 4.75"[ch8232]
    Weight Hull only: 495 lbs[ch8232]
    Fully rigged: 900lbs
    Fuel Capacity: 15 gallon
    Max Horsepower: 60
    Standard Features:[ch8232]
    - Vacuum-infused cored hull
    [ch8232]- 2 piece construction
    [ch8232]- Starboard and Port 10' lockable rod/dry storage lockers
    [ch8232]- 316 stainless lockable hatch latches
    [ch8232]- rubber gasketed hatches
    [ch8232]- Custom poling platform
    [ch8232]- Stainless flip-down push pole holders (3)
    [ch8232]- Custom removable seat/storage box with cushion[ch8232]
    - Taco heavy duty rub rail[ch8232]
    - 15 gallon composite built-in fuel cell
    [ch8232]- Sea Dek on floor
    [ch8232]- Stainless steel shark eye navigation lights & LED anchor light
    [ch8232]- Blue Sea switch panel[ch8232]
    - 12 volt plug-in
    - Sea Dek reel protection pads
    [ch8232]- Fuel gauge[ch8232]
    - Automatic 750 gph bilge pump
    [ch8232]- Built-in battery tray for trolling motor battery and charger
    [ch8232]- 1500 lb galvanized trailer
    [ch8232]- Coast Guard approved and certified
    View the rest of the pictures here:
    http://imgur.com/a/eu1tU#0
    youtube walkthrough, it's shaky but better than nothing:
    http://youtu.be/_bcQbDlv_JY
  2. Bmahoney
    Bmahoney I Love microskiff.com!
    11
    Still have this? Runs good? Anything wrong?
  3. cdaffin
    127
    Yep still got it. Runs fine, took it out recently.
    It has no live wells, which is why I have not sold it yet.
