Just took her back in today to get this issue resolved. Bought the boat a couple months back, bad cylinder one spark plug. Got a tune up and changed it no problem by the Evinrude service place here in Jax.
8 hours later at idle it was running rough again. Took her back and happened to have both plugs bad. They said if it acts up bring her back again and we can resolve what the issue is that's throwing the spark plugs.
This weekend (maybe 8 hours later on the motor) it happened again when docking the boat to trailer it home at the end of the day. Besides the idle she will run great. The service crew is gonna run tests on it to figure out if its coil packs or bad injectors.
Anyone running into this same issue on some older model Etecs?
Besides this small issue I do love the motor. Runs great and starts up first time every time without hesitation.
What size motor? Is your service outfit a full warranty center (with factory trained techs...)? Plugs shouldn't foul on an E-Tec unless there's some underlying issue that's not been diagnosed properly.... Since that motor is every bit of eight or more years old I'd want a careful diagnosis by a factory trained tech.... with the correct year/model software for that particular motor...
Discussion Starter #3
They are all quality trained techs. Top place in Jax for Evinrude service and sales. They are diagnosing it now. Might be the coils or injectors going back that are throwing the plugs. I'll know any day.
Where you got it Becks? I prefer Andy Albirtton marine service, Andy is the best Johnson/Evinrude guy around, then again haven't seen him in years he might of retired.
Discussion Starter #5
Yea I like the guys at Becks. I've worked with them before. Great guys. I've heard of Andy.
Found out the issue. Unfortunately it was the EMM (motor brain) a $1300 hit. Those Etecs have a multi fire sequence at idle hat apparently the EMM kept that multi fire going and not switching over after idle to a solid spark once the throttle was engaged. This was burning the electrode down on the cylinder one spark plug every 5-8 hours.
After check the coils, injectors spark plugs and all other components and talking to Evinrude tech support this was apparently the underlying issue. They checked the sparking sequence before and after the EMM swap and said its firing right now and before it was all out of whack. This in turn should all be behind me now. (Knock on wood).
