Asking $6,000
- 06' Yamaha Four Stroke F20. 4-blade stainless prop, runs great. Oil Change and lower unit oil changed summer 2017 and replaced the spark plugs and water pump around then too. Performance numbers are 27 mph with just me, in the 21-23 mph range with a passenger depending on load and wind.
-Tibor Push Pole Caddy
- 2 new JL 6 inch speakers, wires to Sony blue tooth head unit in hatch.
- New AGM West Marine battery included. Still under warranty.
- Trim Tabs (left one will not go up, haven't had time to figure out why)
- Stick-it anchor
- Charging circuit to a 12 volt battery in hatch
- Comes with 3gal and 6gal gas tanks
- Custom mount and wired for a 12 volt trolling motor
- bilge pump wired to the 12 volt
- Wired to power a SIMRAD or Lowrance unit (no transducer) with a RAM mount
- 3 Gallon Gas tank, which sounds small, but with a passenger it's a full 33 mile range in the wind, Also sold with 6 gallon tank.
- The Blue Camo on the bow and stern are a type of sea deck, but not exactly the same (can't quite figure out the name of the material as previous owner added that, but it's kind of like a tail pad on a surfboard)
- The decking on the stern below the poling platform is Marine tek, and actually a nice add when piloting while sitting on the poling platform
-Ramlin Trailer with new tires, winch, strap, leaf springs and bearings (I dry launch only with it, and can literally launch anywhere)
-note* manual tilt on motor is missing a spring which should be an easy fix but just haven't had time.
- Boat's located in St. Augustine, FL
Motivated to sell - TJ 305-731-4826
- Stick-it anchor
