SOLD/EXPIRED ~2005 Ranger Phantom 168~ $14000
Discussion in 'Sold/Expired Classifieds' started by timj, Jun 30, 2014.
  1. timj
    timj Well-Known Member
    73
    Nada: http://www.nadaguides.com/Boats/2005/Ranger-Boats-Wood-Mfg/168-PHANTOM_/10222923/values
    Located on Pine Island Florida in Bokeelia.
    I love my "micro" but it is just too small for the family so we have put a deposit on a 22 footer which means it's time to let this one go.
    It is a 2005 Ranger Phantom 168 with a 2005 Yamaha 60 high thrust sitting on a ranger trail trailer.
    [table][tr][td]Details: 2005 Ranger Phantom 168 [/td][td]Specs from Ranger:[/td][/tr]
    [tr][td]
    -2 tone hull seafoam gream and white, seafoam cockpit and console
    -Powertech 4 blade Stainless prop - RXB4 13 pitch averages 30mph WOT
    -Extra 3 blade 14pitch quicksilver stainless prop
    -Lenco trim tabs
    -6" hydraulic Jackplate
    -Minnkota 55lb hand control trolling motor with quick release bracket
    -Battery tender 100amp flush mount plug for trolling motor
    -trolling motor battery replaced august 2013
    -800gph bilge pump
    -800gph pirrahna livewell pump new last month
    -FlowRite Power aerator
    -replaced all the switches, breakers and covers this past winter
    -New float switch on bilge pump last September
    -New anti siphon valve fuel lines from tank to motor, water seperator,
    bulb, inline filters on motor and VST filter was cleaned (Don't fill your boat with Jerry cans ugh!)
    -newer water pump replaced last October
    -Just replaced lower unit oil
    -18 foot Moonlighter push pole
    -fusion stereo system
    -Custom font Vinyl registration letters
    -Custom Full Cover new last September was $500
    Trailer:
    -Ranger Trail aluminum trailer
    -New LED lights and wiring
    -5 spoke aluminum wheels
    -spare tire
    -New tongue jack
    -stainless fenders
    [/td][td]Capacities
    16' 8" . . .  . . . . . . . . . . . . . . . . . .Overall Hull Length
    83" . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Beam
    84 1/2" . . . . .. . . . . . . . . . . . .Overall Beam w/Rubrail
    60 - 75 . . . . . . . . . . . . . . . . . . . . . .Max Horsepower
    20" . . . . . . . . . . . . . . . . .. . . . . .Engine Shaft Length
    11 1/2" . . . . . . . . . . . . . . . .. . . . . . . . . .Inside Depth
    6" . . .Draft (Engine up, batteries, fuel and accessories)
    15 . . . . . .. . . . . . . . . . . . . . . . . . .Fuel Capacity (gal)
    16 . . . . . . . . . . . . . . . . . . . . . .Livewell Capacity (gal)
    1070 . . . . . . . . . . . . . .Total Persons, Motor, Gear (lb)
    650 . . . . . . . . . . . .Approximate Deck/Hull Weight (lb.)
    Rod Box Lengths
    10'/9' . . . . . . . . . . . . . .  . . . . . . . . . . .Port
    10'/9' . . . . . . . . .. . . . . . . . . . . . .Starboard
    [/td][/tr][/table]
    This boat is great when you need to run skinny or to not have to worry about if it's going to get skinny truly floats in around 6" of water.  I wish i could keep it but we can't afford 2 payments :'(
    PM me of you want more info or would like to come check it out.
  2. timj
    73
    This is in 1' of water and what it's made for:
    Skinny
    My wife can pole it all day long. (chartplotter not included just got it as a b-day present)
    Powertech Prop:
    This is an older photo but it's what she looks like on the trailer:
    I will post more photos soon
  3. daveIII
    daveIII I Love microskiff.com!
    1
  4. timj
    73
    Additional Info: I took the boat in to have the motor scanned and this is what I got:
    606 hours on the motor
    no fault codes
    diagnositics all came back normal
    I have the print out that I can forward to anyone who would like to see it.
    A few things I forgot to list about the trailer:
    torsion axles
    turbo lube hubs - these things rock stay cold all the time
    stainless fenders
    new winch strap
    new tongue jack
    new safety chains
  5. Kevin23
    Kevin23 I Love microskiff.com!
    25
    What is the Cruising RPM/ Speed and the WOT speed? how is the decking, from the pictures looks a little yellow, I know pictures can be decieving
  6. shiprock8
    shiprock8 HB Whipray 16
    583
    27
    153
    Nice boat! Is your wife available for poling? ;D
  7. timj
    73
    Seldom!  With 2 baby girls its hard to get her up there so I spend most my time on the trolling motor.  If I watched the babies she would probably love to go push you around.  she might teach you how to fish to :p
  8. truman
    truman I Love microskiff.com!
    2
  9. timj
    73
    SOLD
    SOLD
    Thank you to all who showed interest in the boat.
