Putting my ECC Gladesman up for sale. The hull, engine and trailer are 2005. Boat is very clean throughout and has been meticulously maintained.
Since owning it, I have added the stern-eyes, fire extinguisher, and refinished the push pole with Epifanes 2-part polyurethane. On the engine I changed the spark plugs, anode, water pump, shift linkage guide (this was missing when I bought the boat), and lower unit oil. All this was done within the last 6 months with OEM parts and lubricants. The engine idles and runs flawlessly. The Ram-Lin trailer has a torsion axle and walk board - you will not find a higher quality trailer in this class of boat.
I am located in Savannah, GA, however, depending on timing, I will consider driving the boat as far as Daytona Beach, Tallahassee, or Charleston if the buyer will kick in for fuel.
$8,500.00 firm
Contact me at Kachnycz[email protected]
HULL
ENGINE
TRAILER
$8,500.00 firm
HULL
- 2005 East Cape Gladesman
- Fiberglass hull with Kevlar top
- Aluminum poling platform and grab bar
- Black anodized aluminum manual jack plate
- Lenco trim tabs
- 6 gallon portable gas tank located in the bow
- Under-gunnel LED lights (white)
- Accon pop-up navigation light, flip up anchor light mounted to poling platform
- Pop-up forward cleat
- Battery in aft hatch for lights and trim tabs
- 19.5’ Carbon Marine Mangrove sectional push pole
- Black HDPE toe rail on bow and aft deck
- SeaDek padding aft and on rod storage
- Removable seat cushion
- Gemlux stern eyes
ENGINE
- 2005 Mercury 15 HP 2-stroke
- Shallow Water Solutions tiller extension with kill switch
- New spark plugs
- New water pump
- New zinc anode
- New shift link guide
- New oil in lower unit
TRAILER
- Ram-Lin custom galvanized trailer
- Torsion axle (no leaf springs to rust out and replace)
- Diamond plated walk board
- Transom tie down straps
- Transom saver for engine
- Removable tongue
- Spare tire
