SOLD/EXPIRED 2004 BayCraft 155 Flats Edition - $11500
Discussion in 'Sold/Expired Classifieds' started by joekidd81, Jan 12, 2012.
  1. joekidd81
    joekidd81 I Love microskiff.com!
    6
    -2004 BayCraft 155 Flats Edition Flats Boat.
    -2004 75hp Mercury Classic 2-Stroke (approx 400 hrs) 110 PSI compression on all 3 cylinders.
    -2004 South Sport Galvanized float-on trailer w/ 2 new tires.
    -82LB thrust Motorguide trolling motor.
    -Lenco trim tabs.
    -New Garmin 441S GPS with transom-mounted transducer and owners manual.
    -19.5ft CarbonMarine Mangrove carbon-fiber pushpole.
    -Bilge pump.
    -2 live-wells with aerators.
    -Onboard battery charger.
    -3 new batteries.
    -Stainless steel harware and stearing wheel.
    -Transom-saver unit.
    -Anchor w/ 100 ft rope.
    -(2) 15ft dock lines.
    -Boat is turn-key, super clean, can do 30mph, poles in 1.5ft of water with gear and 3 fishermen.
    Asking $11500. Call Joe at 540-455-6605, or send PM.  Located in SW Miami,Fl.
    See more pics at:
    http://www.flickr.com/photos/74266708@N08/with/6686042817/
    Thanks for looking!
  2. flying_rob
    flying_rob Guest
    What is the draft of of the boat?
  3. joekidd81
    6
    With no gear or fishermen, I would say about 10-12 inches.  I mainly do fly-fishing so my live-wells are usually empty and not adding weight to the stern.  It's pretty versatile in that it can do the backcountry and will also cut through the bay with an amazingly dry ride.  2 batteries for the TM are mounted up front to displace the weight better while the third is in the center console, thereby eliminating as much dead weight as possible from the stern.
  4. Live4Reds
    Live4Reds I Love microskiff.com!
    20
    Wow, my '01 155 is only rated for a 60HP, I bet that thing flies with the 75.
    I'll second the dry ride.  I can pole almost as far back as my friend who mans a 15T, but stay a lot drier and more comfortable  :)
  5. joekidd81
    6
    75hp is the max rating for this '04 and it really does fly. The hull design on these BayCrafts is top notch. Super dry and shallow. Pete Lopez and his crew know what they're doing. Thanks for your comments and for looking.
  6. joekidd81
    6
    Price Reduction : $10,500
  7. joekidd81
    6
    Price Reduction: $9,500.
    -Looking at a possible move soon and I don't use it enough to justify holding on to it. This is a good little deal for anyone who can take advantage of it.
    -Joe
    540-455-6605
  8. joekidd81
    6
