SOLD/EXPIRED 2003 Yamaha 25hp 4-Stroke Tiller
Discussion in 'Sold/Expired Classifieds' started by mtredfish, Mar 6, 2007.
  1. mtredfish
    mtredfish Well-Known Member
    57
    2003 Yamaha F25 (F25-MSHB) w/new prop. Tiller handle, 15" Shaft, Aluminum Prop (13 pitch) runs very clean (and quiet)....Bought for boat, but never ended up mounting it (Thanks to Capt. Ron!!!!) ;D
    Unknown Hours, but is good shape...pulls over easy.
    $1900 OBO
    Yamaha Link "http://www.yamaha-motor.ca/products/products.php?model=1925"
    Call Mike 813-383-4949
  2. captnron
    captnron Guest
    Something about carts and horses? ;) ;D ;D
    Glad you came over to the dark side Mike :)  May the Force, I mean Merc, be with you ::).
  3. mtredfish
    57
    Ron,
    I would actually keep this motor of I though I could refit with steering for the tri-toon. I don't need the "Lilly Pad" to haul a$$ - just push along.
    Do you know if there is an aftermarket kit?
    Mike
  4. captnron
    captnron Guest
    I'm almost positive you can get a kit (or parts). Call your local yami dealer to see and ask for the part number. Then I'll give you a dealer that gives 10% off. I know they sell the kit to add so it would only make sense to go the other way. I'm willing to bet Central FL Marine does it all the time.
  5. mtredfish
    57
    Ron,
    I just had a realization.....it's got no trim/tilt? On the 'noe it's not a problem, on a tri-toon - I want it.
    I'll probably throw it on Ebay.....if it doesn't sell local.
    Mike
  6. captnron
    captnron Guest
    If your going to use it in Zello you want aftermarket CNC which will allow the motor to kick up when you "smash" the rocks. Factory TNT locks the motor down - not goot when playing in the rock garden. ;)
    But that's just my .000000000000000002 sense
  7. litlblusrn4bigred
    litlblusrn4bigred Well-Known Member
    657
    How much does this motor weigh?
  8. mtredfish
    57
    137 lbs.....about 20 lbs heavier than a 2 stroke.
