Need your help guys
I have an 2004 14' skiff that has an Evinrude 15 4 stroke that I picked up recently. Fires right up first pull and idles like a champ. The previous owner installed a solas 4 blade prop right before he sold it to me and never water tested it. Took the boat out with a friend and twisted all the way open I was lucky to make 7mph (GPS). My initial thought was that it was over propped for the weight. Keep in mind the vessel is rated for 4 people or 500 lbs. with us and a little equipment, we were right at 500. So I installed the old prop (9X11 I think) and installed a tiny tach to see where I stood.
Took the boat out this afternoon for some test running. Cranked it up and checked idle, was 625+-50 (didn't realize I had it on the wrong setting (180° instead of 360°)). Twisted it open to full throttle and got on plane ok, checked the tach and it wasn't going any higher than 2600rpm (again, wrong setting). So I doubled that in my head and I assume it was running around 5200ish.
Thing is, this thing doesn't scream like I thought it would at full throttle. It actually doesn't seem like it's struggling at all, I just can't crank it any further. Maxed out at 13 mph with just me! WTH!
When I got home I checked the emissions sticker and it is suppose to idle around 1000 rpm. With a quick setting change on the tiny tach, presto-1000 rpm.
I am only use to running 2 stokes and familiar with the way those things scream when at WOT. This is my first 4 stroke and I feel lost.
I feel I should be getting way more than 13 mph with me in this small boat. I had an old jon boat with full decking and a wide beam with an 83 Johnson 15 2 stroke that would do close to 20 mph with me, my wife and kid.
Please help me get this figured out guys.
Thanks
Thanks
